Internal Cleaning Without Tear Down?
20 replies to this topic
#16 Texas Deere and Horse OFFLINE
  • 15135 Thanks
  • 15577 posts
Posted June 01, 2012 - 10:29 PM
I mix both Seafoam and Sta-Bil in every can of gas I buy, whether it is going to be used in 2 stroke or four stroke small engines. I have done this for several years with no issues. Since I started using this mix, I have had no starting or carb issues in any of my small engines. I started using this mix because I got tired of rebuilding my carbs. on anything that sat for more then a couple months.
  • redcarkids and goodnews have said thanks
#17 DanP OFFLINE
DanP
  • 330 Thanks
  • 491 posts
Posted June 02, 2012 - 05:08 AM
It was on tractors, a motor is a motor just use a smaller amount.
#18 Cvans OFFLINE
  • 9625 Thanks
  • 7319 posts
Posted June 02, 2012 - 09:31 AM
You should be able to use either in a small engine. The combustion process is the same in both large and small engines. I would not be afraid to try it using the directions on the can as a guide.
I would also agree with those that have recommended removing the head for a thorough cleaning. The spritz bottle and water was also a good suggestion and should be considered. Water injection has been around since before WWII. Just be aware that the engine needs to be at normal operating temps and a little water at a time goes a long way.
Good luck,
  • redcarkids said thank you
#19 goodnews OFFLINE
goodnews
  • 126 Thanks
  • 423 posts
Posted June 02, 2012 - 10:21 AM
good morning to all its a beautiful day in the tarheel state hope you all had a blessed morning i have .
now. about the mixing ratios would you'll say 1 oz.toa gal. 1 oz. to 2 gal. and etc. i'm thnking 1 oz. 2gal. we also have smigans and dabs lolo.
if you died today where would you spend eternity?
solution- Romans 10:8 -13 please read, thanks
Edited by goodnews, June 02, 2012 - 10:21 AM.
#20 Cvans OFFLINE
  • 9625 Thanks
  • 7319 posts
Posted June 02, 2012 - 06:31 PM
If you follow the manufacturers directions you should be risking nothing. If you dilute it too much you will probably not be happy with the result as enough of the product will not be passing through the engine to do it's job correctly. These products are not known for causing any harm when used in the ratios that are recommended. As stated earlier, some people administer these product in such large quantities as to smoke up the whole neighborhood and no harm is done.
Good luck and let us know how it turns out and when the pieces quit falling.
Just kidding :smilewink:
#21 redcarkids OFFLINE
redcarkids
  • 246 Thanks
  • 470 posts
Posted June 02, 2012 - 07:05 PM
Thanks for the suggestions. will let you know how it comes out.
