New /used Tractor Id
13 replies to this topic
#1 Dons916 OFFLINE
Dons916
  • 26 posts
Posted May 31, 2012 - 10:03 AM
I just got another tractor yesterday.It is supost to be Wards.It has been painted (spray can) power blue.EVERYTHING. Before I really bug all you, where would the ID tag /number be. I have a JD and a Bolens. It is not where these are. It is a hydro 16hp.This is a good running but very ugly tractor.
#2 Dons916 OFFLINE
Dons916
  • 26 posts
Posted May 31, 2012 - 03:15 PM
I took some pic, of that wards tractor,but can't figure out how to post them HELP
#3 JDBrian OFFLINE
  • 9,613 Thanks
  • 14,144 posts
Posted May 31, 2012 - 03:28 PM
Don, in the "Reply to this topic" box you will see a "More Reply Options" button in the lower right corner. Click on that and it will take you to the full editer. At the bottom of that window you will see "Attach Files" and a Choose Files button. This is where you select your photos. It's pretty straight forward after that. There are 2 versions of the uploader, basic and advanced. If you are having trouble loading with the basic version try the advanced! If you need more help just let us know.
  • Dons916 said thank you
#4 Dons916 OFFLINE
Dons916
  • 26 posts
Posted May 31, 2012 - 05:55 PM
Like my post above. i have no clue about the year or serial numbers. Any ideas?SANY0002.JPG SANY0006.JPG SANY0004.JPG
#5 MH81 OFFLINE
Posted May 31, 2012 - 06:16 PM
Wish I could say I could give you some answer, but I can't.
Best I can do is wish you good luck and say that tractor has lots of potential.
#6 Dons916 OFFLINE
Dons916
  • 26 posts
Posted June 01, 2012 - 10:10 AM
Would the older manualls be about the same.It has a Hydro with hi and low range.The leaver for switching is eather stuck or i'm going about it wroung
#7 MH81 OFFLINE
Posted June 01, 2012 - 05:19 PM
:bump:
Anyone have any ideas?
#8 KennyP ONLINE
  • 37,509 Thanks
  • 45,512 posts
Posted June 01, 2012 - 05:31 PM
First, Welcome, Don. I haven't a clue, but it does look Wards. Maybe a Gilson made unit?\
Did some searching thru the Gilson threads and found this:
http://gardentractor...y-this-tractor/
Looks very similar in the grille!
#9 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted June 02, 2012 - 10:34 AM
It is a later model Gilson/MW tractor. I can't tell you exactly what year. I will do some more looking around.
#10 Dons916 OFFLINE
Dons916
  • 26 posts
Posted June 03, 2012 - 10:59 AM
Thanks Texas Deer I would really apprecate it so I could get the manuall for it or just info would be great also.
Thanks again. Don in CA. Do you know the color of them. RED????
#11 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted June 03, 2012 - 11:18 AM
Different colors for different years, but I think it would almost old Case farm tractor Red/Orange, I think..
#12 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted June 03, 2012 - 11:27 AM
Here are some photos of different color schemes from the net,
#13 MH81 OFFLINE
Posted June 04, 2012 - 07:14 AM
Wow, they did use a bunch of color schemes. Almost looks like you could take your pick LOL.
The ones with your grill look yellow / white (or all red in the other thread... Repaint?)
#14 Dons916 OFFLINE
Dons916
  • 26 posts
Posted June 06, 2012 - 09:44 AM
I'm going to repaint,But lots of ether things it needs first.Sure wish I could get the manual for it,But not knowing the yr. makes it tough.Found the ID sticker But it was taped over took great care in removing it,But was not able to save it.Just keep searching I have a Bolens to use. I you know how to switch the Hydo. from low to hi that would help a lot.Don't want to force it without knowing.
Thanks Don in Ca.
