Purists, Please Don't Look
22 replies to this topic
#16 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted May 31, 2012 - 08:24 AM
As a working machine the new OHV motors are a good transplant. They sip fuel and run so much quieter than the originals.
I have one of the no name Briggs that came on my Troy Bilt Super Bronco bought new last year. And could not be happier.
You did a very nice and tasteful mod on the hood. I think that will make for a very useful tool.
#17 El Exorcisto OFFLINE
El Exorcisto
  • 15 Thanks
  • 43 posts
Posted May 31, 2012 - 11:52 AM
Amigatec, I traded it for a moldboard plow and set of discs. I figure an engine that doesn't run in trade for every garden I'll ever put in was definitely worth it.
#18 El Exorcisto OFFLINE
El Exorcisto
  • 15 Thanks
  • 43 posts
Posted May 31, 2012 - 07:12 PM
I got the front end painted and wired up the handlebar kill switch. There isn't a nice way to mount a throttle cable with the current setup, so it's going to be a "set it and forget it" proposition, which isn't much of a problem with the speed changer.
Next up is a 30 cal ammo box filled with lead ingots. I'll u-bolt it to the strap that the saddle bar nuts through, mainly for added traction while I'm plowing snow next winter (I know, MUCH too early to even think about it).
#19 El Exorcisto OFFLINE
El Exorcisto
  • 15 Thanks
  • 43 posts
Posted June 04, 2012 - 09:18 AM
I went to change the rear-end lube yesterday and found the gearbox completely empty. I bet it never got filled when it was brand new, so has lived 57 years with a dry gearbox. Hopefully no damage has been done.
#20 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,026 Thanks
  • 3,172 posts
Posted June 04, 2012 - 01:07 PM
I'll bet the seal are bad, my 560 leaks too.
#21 plumberroy OFFLINE
plumberroy
  • 12 Thanks
  • 18 posts
Posted August 12, 2012 - 05:35 PM
I have all way wanted to find one of the bradleys with the locking differential and put a diesel on it. don't see it happening but it would be a fun toy
#22 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted August 12, 2012 - 09:13 PM
At least it's saved from a junk yard, and working, mods don't look half bad from here, :thumbs:
#23 cookiemonster OFFLINE
cookiemonster
  • 409 Thanks
  • 1,274 posts
Posted August 13, 2012 - 07:56 AM
Dang, that thing looks fast just sitting there!
And, you're right, folks who put modern engines in old machines should be burned at the stake!
bahahaha
Edited by cookiemonster, August 13, 2012 - 07:57 AM.
