Power King 3pt- No Reserve
This topic has been archived. This means that you cannot reply to this topic.
2 replies to this topic
#1 Ryan313 OFFLINE
  • 3,360 Thanks
  • 5,228 posts
Posted May 30, 2012 - 03:25 PM
http://www.ebay.com/...=item1c278a5290
#2 chris m ONLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted May 30, 2012 - 07:51 PM
I bet this one will get interesting at the last 10 seconds of the auction. Do you have this set up already Ryan?
#3 Ryan313 OFFLINE
  • 3,360 Thanks
  • 5,228 posts
Posted May 30, 2012 - 08:35 PM
I have the 3pt on my '75, the '71 only has a drawbar. That one is for the later style PKs. All steel body tractors from '79 and after had this set-up. Before that the hydraulic cylinder was next to your right foot and it moved an arm with a rod hooked to it that moved the 3pt up and down. This style has the cylinder go directly to the 3pt. To make it fit the older style all you would need to do is weld an arm to the side.
