D4-10 Rear Axle Seal Made Of Felt?
18 replies to this topic
#1 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,458 Thanks
  • 3,365 posts
Posted May 29, 2012 - 08:30 PM
Well my rusty one is running but leaking out of one of the rear axle seals.....I pull off the hub and there is a felt ring on it...........so I pull the hub off of a donor transaxle......and sure enough ...same "seal"....
So what do I replace it with?????
#2 IamSherwood OFFLINE
  • 8,390 Thanks
Posted May 29, 2012 - 08:42 PM
Winter is a long way away. :smilewink:
#3 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,458 Thanks
  • 3,365 posts
Posted May 29, 2012 - 08:48 PM
So I get more felt 'seals" ?? All we have around the house is Xmas felt....greens and reds and I don't think thick enough for this job. :blush2: So I am thinking cutting the Xmas Stockings is out of the question.....
Edited by sacsr, May 29, 2012 - 08:48 PM.
#4 olcowhand OFFLINE
  • 40,374 Thanks
  • 31,177 posts
Posted May 29, 2012 - 08:49 PM
This felt thing is more of a wiper. The true seal should be behind the ball bearing. The true seal is part S2700.
  • sacsr said thank you
#5 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,458 Thanks
  • 3,365 posts
Posted May 29, 2012 - 08:57 PM
Darn......so I got to pull the whole transaxle and take that side tube off to get to it?
I just spent about 30 minutes filing down the axle where the previous owner had used a hammer to try to get the hub off.......it was somewhat mushroomed by the time I got it... had to file down the axle and regroove the threads.......finally got it where the nut would go on!! This is the one I was having a hard time pulling the hub......bought a 6" gear puller (my other was smaller)......hooked it up and it came right off ....did not even need to use the heat!....
Edited by sacsr, May 29, 2012 - 08:58 PM.
#6 JDBrian OFFLINE
  • 9,613 Thanks
  • 14,144 posts
Posted May 30, 2012 - 05:06 AM
Glad it came off of there that easy. Those can be a misery to deal with sometimes!
#7 MH81 OFFLINE
Posted May 30, 2012 - 06:29 AM
Good to hear you got the hub off. My experience, felt is just a dust protection piece, gotta be something else in there.
#8 MH81 OFFLINE
Posted May 30, 2012 - 06:32 AM
Sorry, just saw Dan had already said that above. :wallbanging:
Need more coffee.
#9 DanP OFFLINE
DanP
  • 324 Thanks
  • 483 posts
Posted May 30, 2012 - 12:13 PM
What model is it? D4-10 not sure what that is.
#10 olcowhand OFFLINE
  • 40,374 Thanks
  • 31,177 posts
Posted May 30, 2012 - 01:05 PM
#11 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,458 Thanks
  • 3,365 posts
Posted May 30, 2012 - 01:24 PM
Daniel any chance you have that deal number written?
I ran out of daylight yesterday and I am floating away today with all this tropical rain
#12 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,458 Thanks
  • 3,365 posts
Posted May 30, 2012 - 01:25 PM
SEAL number
#13 olcowhand OFFLINE
  • 40,374 Thanks
  • 31,177 posts
Posted May 30, 2012 - 02:23 PM
Scott, I never wrote it down, but I have a tube off a transaxle & it "may" have the seal intact enough to read. I know the bearing was shot though, so the seal may be damaged beyond reading.
#14 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,458 Thanks
  • 3,365 posts
Posted May 30, 2012 - 03:48 PM
No big deal I can look at one tomorrow once the rain stops
I am trying to write down all the bearings and seal numbers as I go for future reference
#15 olcowhand OFFLINE
  • 40,374 Thanks
  • 31,177 posts
Posted May 30, 2012 - 03:54 PM
On these old tractors, I usually just take readings with a dial caliper then order seals according. Lots of these older seal numbers aren't good for crossing anyway.
  • IamSherwood and sacsr have said thanks
