Ss16 Twin Onan Timing
2 replies to this topic
#1 iron Mike OFFLINE
iron Mike
  • 36 Thanks
  • 82 posts
Posted May 29, 2012 - 02:21 PM
Hello from maine. I have two SS16 Twins and I would like to hear from some of you about timing these Onan twins. I went by the book and didn't have a lot of luck. Someone else posted a different way but I forgot who or where.
Both of these tractors flood under heavy load and the engines finally just quit. After they sit for a few they fire right up and run fine. I am thinking this has more to do with the main jet setting than timing but I would still like some feedback(tips) on timing. Thank you all in advance. Mike
#2 KennyP ONLINE
  • 41,465 Thanks
  • 47,393 posts
Posted May 29, 2012 - 03:18 PM
iron Mike, I'm sure someone will be along to help, but do you have some model #'s for these engines? That may have a lot of influence on the answers you receive! Thanks!
  • iron Mike said thank you
#3 olcowhand ONLINE
  • 43,147 Thanks
  • 32,005 posts
Posted May 29, 2012 - 06:02 PM
The SS16 uses an Onan BF engine.
Timing is 21 degrees BTDC (cold static initial, best to recheck with strobe light)
point gap approximately .020"
spark plug gap .025"
valve clearances EX: .013" IN: .008"
  • MH81, KennyP and iron Mike have said thanks
