Cub Cadet 109 Steering Question
7 replies to this topic
#1 jdslednut OFFLINE
jdslednut
  • 678 Thanks
  • 851 posts
Posted July 02, 2010 - 11:08 PM
I have a question related to Poncho62's. My 109 turns great to the left but maybe 50-70% of that to the right. Is there a common problem/quick fix to this in the adjustment?
#2 olcowhand ONLINE
  • 40,355 Thanks
  • 31,172 posts
Posted July 03, 2010 - 08:49 AM
Sounds like you need to adjust your steering control links. Turn steering wheel full left, then full right. Count the steering wheel revolutions, then turn steering wheel to center. You should find your wheels are pointed toward left instead of center. Leave steering wheel at center, then adjust your steering link (or links depending on the system) from steering box to spindle till wheels are centered.
Edited by olcowhand, July 03, 2010 - 09:17 AM.
  • jdslednut said thank you
#3 onan302 OFFLINE
onan302
  • 4 Thanks
  • 64 posts
Posted August 22, 2010 - 09:41 PM
There also might be a chunk of teeth missing from the gear on your steering connecter. if there is, you can probably weld new teeth a little oversize, and then grind them down to fit the other teeth.
#4 mulefarmer25 OFFLINE
mulefarmer25
  • 3 posts
Posted October 25, 2010 - 09:17 PM
I have a 122 that wont turn to the left at all but fine to the right any ideas.
#5 jdslednut OFFLINE
jdslednut
  • 678 Thanks
  • 851 posts
Posted October 25, 2010 - 11:32 PM
I am set to try Olcowhand's method any time now as my 109 is up on blocks. Just have to find time.... I would suggest that.
#6 NUTNDUN OFFLINE
  • 10,336 Thanks
Posted October 27, 2010 - 06:36 PM
Keep us posted :D
#7 caseguy OFFLINE
  • 1,627 Thanks
Posted October 27, 2010 - 07:52 PM
What happens when you try to turn it to the left? Does it skip teeth?
#8 jdslednut OFFLINE
jdslednut
  • 678 Thanks
  • 851 posts
Posted October 27, 2010 - 11:16 PM
Followed Olcowhand's advice and voila! It appears to be centered, at least on the stands anyway. Will do an off-road trial when time permits.
