Briggs & Stratton Carb/gas Tank Swap
5 replies to this topic
#1 cadman56 OFFLINE
cadman56
  • 42 Thanks
  • 34 posts
Posted May 27, 2012 - 06:46 PM
I have two B&S engines that I'm trying to make one good engine. I'd like to swap the carb/gas tank assembly from this engine:
Model #: 92502
Type #:3101 01
Code #: 82063009
To this engine:
Model #: 92902
Type #: 1017 05
Code #: 79013122
Visually it looks like it could be done. The only difference according to the numbers is the 92502 has a Vacu-Jet carb and the 92902 has a Pulsa-Jet carb. Does anyone know, can this swap be done?
#2 DougT ONLINE
DougT
    Dog Approved
  • 6,764 Thanks
  • 4,908 posts
Posted May 28, 2012 - 02:57 PM
I don't see any reason it couldn't be done. You may have to change the governor linkage too so it matches.
  • cadman56 said thank you
#3 cadman56 OFFLINE
cadman56
  • 42 Thanks
  • 34 posts
Posted May 29, 2012 - 06:38 PM
Thanks Doug for the reply and also the heads up on the governor linkage. I'll be sure to check the linkage out when I get back to that job, (wife just revised the HDL), and this job got pushed down on the list!
#4 MH81 OFFLINE
  • 29,963 Thanks
  • 29,757 posts
Posted May 30, 2012 - 07:04 AM
Wish I could help, but not up on the finer points of Briggs-dom.
When the HDL gets short enough, let us know how it worked out.
#5 stpking OFFLINE
stpking
  • 1 Thanks
  • 1 posts
Posted June 07, 2012 - 03:52 PM
If you run into parts issues, I noted an engine on Ebay thats listed for parts, Briggs 92902, 1017-05.. I recently picked up the recoil starter cover from this engine. Heres the link:
http://cgi.ebay.com/...em=120928882460
#6 cadman56 OFFLINE
cadman56
  • 42 Thanks
  • 34 posts
Posted June 07, 2012 - 08:57 PM
Thanks stpking for the info. I'll have to check that out.
