Mower Deck Alignment Issue ~ '89 Jd 265 Hydro...
6 replies to this topic
#1 jd265 OFFLINE
jd265
  • 2 Thanks
  • 22 posts
Posted May 27, 2012 - 11:55 AM
I just now realized that there are specific forums here... I get it now. I had posted this in the general GT discussion forum. Doh...!
Hey all,
Gotta love finding a forum on John Deere tractors, this is great.
We have an '89 265 Hydrostatic with the 17 HP Kaw engine, mower deck and we used to plow with it then we purchased a Grizzly to take that chore as we get quite a bit of snow… I still keep a plow on it but just to clean up vs. doing the primary duty. Wheel weights and chains, sweet rig.
My Wife actually bought it for me new for Christmas in ‘89. What a girl..!
I did not even mount the mower for several years, I wanna say maybe more than ten years before I hooked it up and it has really seen little use…
I will try to make this a short story but the issue is complicated.
Well, last year it tossed a mower drive belt at the end of the year so I took the deck off and really did not think much of it until this Spring when I went to put a new belt on.
I put a new belt on it and it tossed another one. That is when I discovered what caused the belt to be spit out…
This time the rear dual pulley crashed into the front of the hydro unit and bent the channel for the belt rendering it unusable. Those are spendy huh…?
The entire deck looks to be set rearward enough (Duh, hence the crash..) to drive that pulley hard into that housing. But why…?
Well, I measured and looked under the tractor and measured some more on the deck, bought new rear hanger brackets and front adjustable tie bars and that read dual pulley. The rear bracket bushings were a little warn but nothing that would cause that much movement.
When I installed the new front bars I adjusted them tighter as to pull the deck forward and the pulley Still hits that hydro housing.
The only other thing that I see is that the mounting points of the rear hangers may be slightly tilted forward which, in my limited knowledge of trigonometry suggests that there might be the issue. However, there is no way that those mounts have been bent, they are ¼ angle and the welds do not appear to have been comprised. There are no other signs of the deck being bent
I am not going to put the new belt on just to trash it until I figure this out but I am out of ideas here.
Any advise or ideas what could be causing this alignment issue is most welcomed. I can post photos if need be… In fact I will go out and shoot some right now.
My most sincere apologies for such a long winded first post.
Thanks very much,
Rob
Edited by jd265, May 27, 2012 - 11:56 AM.
#2 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted May 27, 2012 - 03:32 PM
Rob, welcome to the forum. Do you have the manual for the mower deck? JD puts all the mower deck related info. in the mower deck manual only and it's not available in the tractor manual. That may give you a few ideas as to what is happening. If you could post some pictures of the problem it would help others visualize what's going on. You might want to stop by a JD dealer and talk to the service dept. to see if anyone there would know what the issue is. I'm not familiar with those decks so I don't have any specific advice to offer. If you do an online search for this problem you might come up with some info. as well.
#3 jd265 OFFLINE
jd265
  • 2 Thanks
  • 22 posts
Posted May 27, 2012 - 04:25 PM
Brian,
Yeah, I have talked with the dealer and I may just have to have them take a look at it. I do not have the manual for the deck either so I'll have them get me one...
Photos show the dual pulley without the top (drive) belt and how close to the hydrostatic drive housing that it is.
Nothing on the deck that I can see is damaged or distorted enough to cause this rearward position. I am kinda stumped. Looks like it is time to pay 72 bux an hour to have the shop take a look...
Thanks,
Rob
From the right side....
From the left side ...
#4 jd265 OFFLINE
jd265
  • 2 Thanks
  • 22 posts
Posted May 28, 2012 - 07:34 PM
Well I think I found it …
I had replaced the deck hangers that were not deformed what so ever and the bushings where there was a little wear but not enough to make a difference however, the two front adjustable rods were out of shape enough and they seemed to be the culprit… When I hung the new ones I adjusted them up much tighter than the originals.
The pulley was still dangerously close to the hydrostatic drive housing so I spent some more quality time under the rig, confirmed that the stops to the belt tensioning system was set up properly but I decided to install the belt anyway to see how that would affect the clearance.
Well, that did it.. With the belt installed and pulled up tight all is well again. Pulling that assembly up tight pulled the pulley far enough away from the drive unit to pleae me...
I went out and mowed quite a bit this afternoon, even took it through some rough stuff to see if the deck would shift and toss another belt. Nope.
I think it came down to the front hangers though…
Hey, thanks for puttin’ up me while a messed with this issue, this was driving me nuts...!
My JD is back to normal.
Best,
Rob
#5 KennyP ONLINE
  • 40,187 Thanks
  • 46,794 posts
Posted May 29, 2012 - 05:25 AM
Glad you got it figured out, Rob! Some of these issues take a gathering of minds to figure out!
#6 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted May 29, 2012 - 10:11 AM
Glad to hear you got it figured out. The manual for the decks always seems to get lost and then it's hard sometimes to figure this stuff out.
#7 jd265 OFFLINE
jd265
  • 2 Thanks
  • 22 posts
Posted June 07, 2012 - 09:30 AM
Brian,
I have never had a t/m on the deck itself... I know it by heart now though...!
Just another follow up.. I have used the 265 for two or three mowings now since the issue and we seem to be all set. I like my JD...
Best,
Rob
