* * * * * 2 votes
So what started your itch for lawn and garden tractors?
365 replies to this topic
#346 Stroud OFFLINE
Stroud
  • 131 Thanks
  • 53 posts
Posted February 14, 2017 - 07:10 PM
 I can't afford  much else. Just kidding. Went through the drag racing stage, offroading stage, lifted truck stage,and as getting older looking for smaller simpler projects. Seat time is good self time. Now I can understand why as my dad got older he mowed more of the field making his yard larger. I now find myself doing the same. I started with 1/2 acer and now up to almost 2.
  • nitro said thank you
#347 dtsh OFFLINE
dtsh
  • 234 Thanks
  • 157 posts
Posted February 16, 2017 - 01:56 PM
I got into it due to the need of practical solutions to my problems.
I need....
  to mow grass
  to move snow
  to make some of the garden work easier
  to tow, drag, and pull on odd occasions
  something to tinker on when I'm bored
  the solution to fit into the space I have available
  to solve these problems without bankrupting me
A dependable old GT fits all those needs.
  • Alc, jimbobbillyray and Stroud have said thanks
#348 Denis velikanov OFFLINE
Denis velikanov
  • 20 Thanks
  • 8 posts
Posted February 17, 2017 - 05:54 PM
I'll show a photo of his tractor, he helps me a lot. I am building a house, garage and more. The box trailer 1200 kg. and I'm taking. This tractor, I go in the summer. It is small and comfortable with good handling. In the winter or in the rain, I ride on a different tractor.
  • jhn9840, Alc, KennyP and 1 other said thanks
#349 dtsh OFFLINE
dtsh
  • 234 Thanks
  • 157 posts
Posted February 20, 2017 - 01:10 PM
It's amazing how useful even a small tractor can be. I used my Bolens 750 to assist when erecting some buildings here, too. That shear leg/ginpole you have looks handy, I use an 18' wooden one which i put up and take down as needed and store it in the rafters of the garage until needed again. With a block and tackle or other mechanical advantage, a small derrick such as yours, and a little tractor one man can get a whole lot accomplished.
#350 Denis velikanov OFFLINE
Denis velikanov
  • 20 Thanks
  • 8 posts
Posted February 20, 2017 - 04:28 PM
Для более тяжелого веса, я использую другой кран.
Edit: For heavier weights, I use another faucet
The translator doesn't do a good job on that one! Doug T
  • DougT, Gtractor, Alc and 2 others have said thanks
#351 DougT ONLINE
DougT
    Dog Approved
  • 6,768 Thanks
  • 4,911 posts
Posted February 20, 2017 - 06:35 PM
Interesting, Dennis. Are you moving the lathe in or out? I'd like to see some details of the tractor you are pulling the car with too.
#352 Cat385B ONLINE
    HAZMAT CAT
  • 13,540 Thanks
  • 9,828 posts
Posted February 20, 2017 - 09:05 PM
Это выглядит как жесткий маленький трактор. Можете ли вы рассказать нам больше об этом?
Спасибо за фотки!   :camera:
Разве это нормально, чтобы не иметь снег на земле в это время года для вас?
Edited by Cat385B, February 20, 2017 - 09:13 PM.
#353 Cat385B ONLINE
    HAZMAT CAT
  • 13,540 Thanks
  • 9,828 posts
Posted February 20, 2017 - 09:08 PM
Just got the last one wrong, it reads "I use another crane"
#354 Alc ONLINE
  • 6,611 Thanks
  • 7,339 posts
Posted February 21, 2017 - 06:41 AM
I would also like to hear more about you , would you mind starting another thread about how you built your shop and other things about yourself ?
#355 Denis velikanov OFFLINE
Denis velikanov
  • 20 Thanks
  • 8 posts
Posted February 21, 2017 - 05:03 PM
I've been doing a little technology invention from an early age. Father taught me, and I really like. Now we have winter and the pictures were taken in the summer. I bought the land and built himself a house. I bought more machines. We have factories in Russia do little equipment and you need to do yourself. Here in Russia everything is bad.Traffic police and removes all drive carefully, to hide.
For myself, I do a little different technique: cultivators, ATVs, tractors, cranes, trailers ......... I do not shop. On my site you can see the video. Then I realized you can not link (address).
Quietly I am going to tell you about the tractor.
tractor Weight 110 kg. with the motor.
The motor weighs 36 kg. power of 13 hp two-stroke speed of 40 km / h, four forward and four reverse gears, pulls the trailer load of 1200 kg. During the season I pass up to 3000 km. for 20 years but have never broke sending. I refit only changing the engine cylinder and piston.
Main gear bevel gears. Apply on the truck with the differential. Semiaxial diameter of 120 mm. satellite and 70 mm in diameter. Peredachnaya 1.8. Reverse gear unit is the same 1.8. Gearbox and clutch in the motor. From the engine to the gear chain.
Over the weekend, I take photos.
Driving the lower final drive gear:
  • jhn9840 and KennyP have said thanks
#356 Denis velikanov OFFLINE
Denis velikanov
  • 20 Thanks
  • 8 posts
Posted February 22, 2017 - 03:19 PM
Do you understand me ? I'm talking to you through Google translator. If something is not clear ask.
I make new models of small tractors better and better. I bring new ideas check reliability.
#357 KennyP ONLINE
  • 36,553 Thanks
  • 44,992 posts
Posted February 22, 2017 - 04:41 PM
The translator is a bit out of focus, but we are getting a good idea.
  • MGP59DB said thank you
#358 MGP59DB OFFLINE
MGP59DB
  • 1,563 Thanks
  • 734 posts
Posted February 22, 2017 - 06:09 PM
Very nice machine , looks real robust  ! That is some great engineering.
#359 Greasy6020 ONLINE
Greasy6020
  • 1,308 Thanks
  • 1,273 posts
Posted February 22, 2017 - 10:11 PM
I understand fairly well, nice work!
#360 secondtry ONLINE
secondtry
  • 1,468 Thanks
  • 1,184 posts
Posted February 23, 2017 - 12:42 AM
Very inventive build. Did you keep track of the hours required to complete the tractor. Was it built from mostly salvaged parts. Don
