Help With A Kohler Ch20 Crank
1 reply to this topic
#1 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted May 25, 2012 - 02:25 PM
so i may of just got a kohler engine its a command v twin 20 hp well i will take a close look at it before i close the deal the cam gear on the crank broke i have a replacement gear but it is a heat fit so i was wondering if i can get some pictures of the gear in comparison to the lobes on the crank shaft
thanks
Ty
#2 olcowhand OFFLINE
  • 41,150 Thanks
  • 31,416 posts
Posted May 25, 2012 - 10:11 PM
I would think there should be a mark on a tooth of the gear to get it aligned proper. Sometimes instead of a dot or a dash mark, one tooth will have an angled edge,which will align to a certain point on the crank, which should also have a cast in mark of some kind.
