Cutting Cork Gaskets
9 replies to this topic
#1 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,458 Thanks
  • 3,365 posts
Posted May 24, 2012 - 09:48 PM
Okay so today I needed to make a few gaskets......drawing them out was not an issue....cutting the outside edges was simple enough.....used a hole puncher for the bolt holes......so moving along pretty good.....then pulled out the old family exacta knife ( not sure that is the name ....but it is the one with teh razor looking blade at the end)......now it may not have been sharpe enough....but when I finally finished cutting out the middle it was a little ragged around the edges....I am guessing I could buy some small snip type scissors to do the smaller more detail cuts....anybody got any suggestons or ways that you would do this?
  • 14,730 Thanks
  • 15,470 posts
Posted May 24, 2012 - 10:29 PM
I use a sharp wood chisel on a piece of 2X12" pine board, not to dull the chisel. It will cut the cork cleanly. I have 3 different sizes, 1/2" 1" and 2".. Hope this helps..
  • Alc and sacsr have said thanks
#3 MH81 OFFLINE
Posted May 24, 2012 - 11:41 PM
I use a really sharp, new blade in my exacto knife, a set of chisels, and I have a couple of broken curved wood lathe tools that are sharpened up good. I have found the last items to be a good tool if the curve is close enough for what you are doing.
I have almost quit using cork altogether and have switched over to the thicker stuff they sell at automotive stores that looks like charcoal colored paper. (or posterboard sometimes) Much easier to work and rarely rips out.
  • sacsr said thank you
#4 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,458 Thanks
  • 3,365 posts
Posted May 25, 2012 - 06:16 AM
Thanks.....so far cork was all I had found......would love to find the material you are talking about.......will keep asking till one of the auto stores says yes.
#5 Bud OFFLINE
Bud
  • 398 Thanks
  • 415 posts
Posted May 25, 2012 - 07:04 AM
I have a pair of sissors I use on most stuff. I think there made by Fiskers (not sure if I spelled it right) they are a little heaver than normal ones and have a serated outer edge. I also use a punch, some of which are just rifle brass honed or filed a bit to sharpen the edge more and my pocket knife (I keep it razor sharp).
#6 olcowhand ONLINE
  • 40,365 Thanks
  • 31,175 posts
Posted May 25, 2012 - 08:28 AM
This is what I mostly use. Sounds likely to be what Alan uses.
http://www.autozone....fier=67683_0_0_
Instead of plain cork, I use the rubberized cork. Much better seal & life.
http://www.autozone....fier=67680_0_0_
  • JDBrian and sacsr have said thanks
#7 JDBrian OFFLINE
  • 9,613 Thanks
  • 14,144 posts
Posted May 25, 2012 - 09:51 AM
I use what is commonly referred to as a box cutter. I use the Olfa brand cutter with the segmented blade so you can always keep a sharp edge. I've used that rubbarized cork that Daniel is referring to and it seems to seal well.
#8 MH81 OFFLINE
Posted May 25, 2012 - 11:12 AM
yep, that's it.
#9 TUDOR OFFLINE
TUDOR
  • 544 Thanks
  • 497 posts
Posted May 25, 2012 - 01:49 PM
Industrial supply houses are also a good source for gasket material in many different thicknesses.
Gasket thickness is critical in many applications as it sets the internal clearances.
#10 Trent Thomson OFFLINE
Trent Thomson
  • 189 Thanks
  • 229 posts
Posted May 26, 2012 - 07:25 AM
to cut alot of pieces I use a ball peen hammer. Set the gasket material over the metal and tap with the round end lightly on the gasket at about 45 degrees to the edge of the metal. It gives a nice sharp cut avery time.
Edited by Trent Thomson, May 26, 2012 - 07:25 AM.
