582 Video. It's Not Running Right
4 replies to this topic
#1 daytime dave OFFLINE
  • 4,782 Thanks
  • 6,522 posts
Posted May 22, 2012 - 06:24 PM
I took dad's 582 out. He said it was running badly. I took it out discing. You can hear it surge and backfire.
Any help with a diagnosis would be appreciated.
Thanks
#2 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted May 22, 2012 - 06:57 PM
Have you checked the plug ( or plugs) on that yet? From what I can here it sounds like an ignition misfire. Is this points or Electronic ign?
Before jumping the gun on anything else. I would check all connections and the condition of the plugs.
Also if you have a way to drain the fuel bowl on the carb, I would just drain it into something and check for water in the gas.
Check the air filter also.
Good luck.
#3 JDBrian OFFLINE
  • 9,601 Thanks
Posted May 22, 2012 - 07:07 PM
I think those tractors have a 16hp Briggs twin don't they. i have no experience with those at all. If it has points and they are easily accessible then I'd go there after first checking for all the basics.
#4 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted May 22, 2012 - 07:09 PM
It should have a KT17 Kohler.
#5 MH81 OFFLINE
Posted May 22, 2012 - 07:12 PM
Also sound like ignition or sticky valves to me. If it has points, are they gapped right?
