Got A Sears Again!
18 replies to this topic
#16 MH81 OFFLINE
Posted May 28, 2012 - 08:08 PM
OK, it's an HH120, but beyond that, I can't tell you much.
The Sears exploded view shows the style with the pickup outside the flywheel, but the picture is so bad, the pins aren't discernible.
You'll have to tell us if you have the cover off. Just take a picture of the flywheel side sometime if you ever have the tins off & we'll try to be better at answering questions.
Thanks for the follow up
#17 glgrumpy ONLINE
  • 8,604 Thanks
  • 7,909 posts
Posted June 03, 2012 - 12:47 AM
Hey, lucky me! A fella called and saw my ad on here needing a grill insert for the Sears. I bought it and it came and is just right, color and all! Neat! Hard to find those buggers, most are missing. I have engine cover off, and can take a picture of coil shown. That IS a lot diff than the 69's I worked on last. All enclosed in aluminum. Took chassis out to power wash today and much nicer to work on now. Still needs painting to be real nice, but saving that for some other time. Going together now as it is. Need to get under it and replace the drive belt and the brake needs work also. Not sure if brake is just adjust or needs lining on it!
#18 MH81 OFFLINE
Posted June 03, 2012 - 07:43 AM
Wow, congrats. Nice to find those when you actually need one.
#19 glgrumpy ONLINE
  • 8,604 Thanks
  • 7,909 posts
Posted June 04, 2012 - 01:32 PM
Took couple pix of the ignition coil on the engine. All enclosed in aluminum. Diff than what was on my 69 SS12.
