Stick welding sheet metal
2 replies to this topic
#1 fordmustang1984 OFFLINE
fordmustang1984
  • 24 Thanks
  • 428 posts
Posted June 30, 2010 - 01:30 PM
What is a good rod for welding sheet metal? Particularly the stuff GT hoods are made of. Also, whats a good amperage? I had it written down in my welding notebook but can't seem to find it.
#2 olcowhand OFFLINE
  • 37,713 Thanks
  • 30,339 posts
Posted June 30, 2010 - 02:22 PM
Someone else will have to help you with that one, because before I got my MIG welders, I used 6011 or 6013 1/8 rods for everything including thin sheet metal. Was a learned thing to use these rods, but I used what I had & got by. 75 amps is what I used, but I recommend waiting for a more professional welder for rod/heat selection.
Edited by olcowhand, July 24, 2010 - 08:00 PM.
#3 caseguy OFFLINE
Posted July 24, 2010 - 02:16 PM
I'm not a professional welder. but here's my $.02. I have always used 1/16th or 3/32, 7014 or 7018 rod for sheet metal. You can turn the current down to 40 or 50 amps, depending on your machine. I also usually stitch in small increments and allow the weld to cool pretty good before continuing. I've found that it helps prevent warping.
