Mf 1200 Resto
1200
27 replies to this topic
#16 JDBrian OFFLINE
  • 9682 Thanks
  • 14162 posts
Posted May 19, 2012 - 06:04 AM
Nice restoration. Thanks for the great pictures. It's interesting to see the frame and transmission. I didn't realize they used an angle drive on these. Pretty sturdy looking frame on it! Your pictures of the plastic dash repair are really nice to have as well.
#17 limebuzz OFFLINE
limebuzz
  • 1155 Thanks
  • 1086 posts
Posted May 19, 2012 - 07:15 AM
Thanks guys still need a couple small decals,a seat and a amp guage and maybe a hour meter.Then I will dive into one of the 5's that I have !
Edited by limebuzz, May 21, 2012 - 06:06 AM.
#18 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted May 21, 2012 - 05:58 AM
Thanks guys still meed a couple small decals,a seat and a amp guage and maybe a hour meter.Then I will dive into one of the 5's that I have !
Oh, you'll like doing the 5. Easy machine to work on, and fun to ride when done.
The part I liked about restoring the 5, is that it's just light enough that
it can be wrestled around and flipped over easily enough. I put it up on a 3 x 6
sheet of plywood on sawhorses. No bending over required.
Suggestion, start soaking the hubs on the rear axles with penetrating oil.
Mine where nasty to get off. I had to put the whole axle in a press, and that
was a real treat, on the left side, because the sprocket is in the way.
Looking forward to updates on that resto.
#19 limebuzz OFFLINE
limebuzz
  • 1155 Thanks
  • 1086 posts
Posted May 21, 2012 - 06:05 AM
Thanks for the tips IamSherwood!I think Im going to need to do engine work on this one though it has no compression at(hopefully a stuck valve)Just started tilling the garden yesterday so mabe a week or two before i start on it!
#20 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted May 21, 2012 - 06:10 AM
Wow, that turned out great. Thanks for the pics.
I have always wondered the same thing about the dash. Makes a guy wonder what horrible set of circumstances can cause that much damage and leave the rest of the tractor intact.
#21 limebuzz OFFLINE
limebuzz
  • 1155 Thanks
  • 1086 posts
Posted May 21, 2012 - 06:29 AM
Ya i've got the next 3 months off of work.I was wondering if I should make a mold of one and see if I couldn't pop out a couple and see if they are any good!I've had five of these tractors and not a one of them have had a good dash.I'm just thinking out loud again.
#22 ckjakline OFFLINE
ckjakline
  • 1192 Thanks
  • 1177 posts
Posted May 23, 2012 - 06:54 PM
Nice job on the restoration.Lookin good! You gave me some good pointers on the dash repair for when i restore my dads 1200.
#23 tinner OFFLINE
tinner
  • 504 Thanks
  • 1561 posts
Posted May 24, 2012 - 09:01 PM
Like your restore, I have a Snapper 1600 which is the same tractor but with a 16hp Kohler. I need to do a little dash repair too. As soon as I get this 18 wheeler load of widgets unloaded, counted and stacked in reversed numerical order I plan on giving her a new coat of paint.
#24 limebuzz OFFLINE
limebuzz
  • 1155 Thanks
  • 1086 posts
Posted May 24, 2012 - 10:10 PM
Can't wait for the pics!!Take lots,cause you can never have tooo many,thats for sure!
#25 chris m OFFLINE
chris m
  • 3350 Thanks
  • 4069 posts
Posted May 25, 2012 - 12:00 AM
That came out great!! I also like how you repaired that dash. And you could never tell this was your 1st resto!
I look forward to seeing your future projects too! :thumbs:
#26 Dom. OFFLINE
Dom.
  • 3 Thanks
  • 9 posts
Posted April 19, 2013 - 04:21 PM
Bonsoir,
Merci pour votre reportage ! :thumbs:
J'ai moi aussi un MF 1200 que je souhaite refaire à neuf.
Le moteur est cassé (bielle cassé), j'ai déposé le moteur Kohler K301 de 12Ch chez un rectifieur, afin de savoir s' il est réparable.
J'attend toujours la réponse, en attendant j'aimerais remettre à neuf le chassis et l'ensemble des autres élèments.
Je n'ai presque pas de budget, mais je suis motivé pour tout refaire moi même.
Patient et bricoleur je ne désepère pas.
J'ai une question, à vous poser: en sortie moteur, une poulie est placée en bout de chassis derrière les phares, il doit me manquer une pièce.
Je pense à un r' envoi d'angle pour que la courroie puisse arriver jusque la polie du plateau de coupe, je n'arrive pas à voir à quoi peu ressembler cette pièce ?
Est ce que le moteur K301 est suffisament puissant pour ce type de tracteur ?
J'ai 4000m² à tondre.
Existe t'il a votre connaissance un moteur qui pourrais remplacer le K301 avec une puissance un peu plus forte ?
J'espère malgrès tout que je pourais à moindre frais remettre en route mon moteur.
Merci pour tous vos conseils, j'ai vraiment besoin de votre aide pour remettre en état ce micro-tracteur.
merci. :wave:
Dom.
Good evening
Thanks for your story!
I also have a MF 1200 I want to redo to nine.
The engine is broken (broken rod), I tabled the engine Kohler K301 12Ch at-a-regulators rectifiers, in order to know if it is repairable.
I'm still waiting for the answer, in the meantime I would like to refurbish the chassis and all the other elements.
I have almost no budget, but I'm motivated for any redo myself.
Patient and handyman I do helpless not.
I have a question to ask you: motor output, a pulley is placed at the end of chassis behind the headlights, it must miss a play.
I think a r' sending angle so that the belt can arrive up to the polished of the cutting deck, I can't see what little look this coin?
Is the K301 engine is powerful enough for this type of tractor?
I have 4000 m² to mow.
Are you there your knowledge an engine that could replace the K301 with a slightly higher power?
I hope despite all that I'm inexpensively switch my engine.
Thanks for all your advice, I really need your help to rehabilitate this tractors.
Thank you.
DOM.
#27 coldone OFFLINE
coldone
  • 1716 Thanks
  • 1709 posts
Posted April 19, 2013 - 10:56 PM
Dom.
Kohler K301= 12hp
Kohler K321= 14hp
Kohler K341= 16hp
Old Kohler                        Newer Kohler
Kohler K model  ---->       Kohler Magnum model
Difference between older (K model)  and newer (magnum model) is ignition system.
Magnum 12= 12hp
magnum 14= 14hp
Magnum 16= 16hp
All models listed should fit your 1200 with only minor differences. All are single cylinder engines.
12Hp is plenty for this tractor. Original engine should be repairable.
Hope the info helps.
#28 Dom. OFFLINE
Dom.
  • 3 Thanks
  • 9 posts
Posted April 20, 2013 - 02:32 AM
Hi
Merci beaucoup de votre aide
J'ai ouvert un nouveau post pour ne pas polluer celui ci.
Encore merci
Dom.
Thank you for your help
I opened a new post for not to pollute that ci.
Thanks again.
DOM.
Also tagged with one or more of these keywords: 1200
