Question
7 replies to this topic
#1 Kevin Vasich OFFLINE
Kevin Vasich
  • 87 Thanks
  • 174 posts
Posted May 15, 2012 - 08:17 PM
Hi Is this the right sleeve hitch square fenders for 110, 112 to 140?
http://www.ebay.com/...082031400873945
#2 lyall ONLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted May 15, 2012 - 09:32 PM
it sure looks like the one I got that I use on my 110, 212 and 214
you can ask for the measurements of it to be sure that it is the one you need/want
see the following link it is in the manual section here
http://gardentractor...-square-fender/
Edited by lyall, May 15, 2012 - 09:39 PM.
  • 14,792 Thanks
  • 15,492 posts
Posted May 15, 2012 - 09:35 PM
I believe the hitch it's self is the same for both gear and hydro models. The difference is the linkage bar.
#4 Tmo OFFLINE
Tmo
  • 360 Thanks
  • 486 posts
Posted May 16, 2012 - 06:00 AM
That is the right hitch and will fit the square fender gear drives, the 120, the 140, the 200 series, the 300, 312, 314, 316 Kohler and the 317. You will need a rear lift rod for the hydros and a rear lift assembly plus rear lift rod and a rear lift arm for the gear drives.
#5 Trav1s ONLINE
Trav1s
  • 3,283 Thanks
  • 4,347 posts
Posted May 16, 2012 - 09:48 AM
That is a good price too...
#6 Kevin Vasich OFFLINE
Kevin Vasich
  • 87 Thanks
  • 174 posts
Posted May 16, 2012 - 07:42 PM
Will it fit a 74 110?
#7 lyall ONLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted May 16, 2012 - 08:46 PM
if it fits the 200 series it will fit your 110
my fits on my 110, 212, or 214
#8 Littledeere OFFLINE
Littledeere
  • 1,650 Thanks
  • 1,483 posts
Posted May 16, 2012 - 09:47 PM
It will fit your tractor but you wil have to have the lift arm and pivot point on your tractor to use it plus the arm that
goes from the pivot the the sleeve hitch
