Removing Steering Wheel
5 replies to this topic
#1 mixedbreed96 OFFLINE
mixedbreed96
  • 11 Thanks
  • 167 posts
Posted May 15, 2012 - 02:30 PM
need some help getting my steering wheel off of my d4-10 does any body have any pics of this task?
#2 olcowhand ONLINE
  • 36,869 Thanks
  • 30,149 posts
Posted May 15, 2012 - 03:36 PM
That will be an almost impossible task without busting the masonite from around the center hub. I believe on all these models, the masonite extends below the metal hub on it's underside, so if you get a bearing separater under it to pull by, it pops the masonite. If the masonite breaks, which it surely will, then use a 2 bolt puller in conjunction with a bearing separater (turned upside down), apply some heat on the hub & pull.
#3 chris m ONLINE
chris m
  • 3,287 Thanks
  • 4,038 posts
Posted May 15, 2012 - 03:53 PM
Like Daniel said, There is just no way around this. If it is rusted on (which they always are) 99% of the time it will break the masonite. my Ford and Jacs have the same problem. Good luck!
#4 IHCubGuy OFFLINE
IHCubGuy
  • 1,430 Thanks
  • 1,515 posts
Posted May 15, 2012 - 06:51 PM
Not all that familiar with the Bush Hogs. Do they have a tapered spline holding the wheel on the steering box like a Ross steering box does? If so you could try the trick I use on my Cubs.
#5 olcowhand ONLINE
  • 36,869 Thanks
  • 30,149 posts
Posted May 15, 2012 - 06:54 PM
Wish they were taper spline! These are keyed like Sears SS are, and man oh man do they come off HARD!
#6 IHCubGuy OFFLINE
IHCubGuy
  • 1,430 Thanks
  • 1,515 posts
Posted May 15, 2012 - 06:59 PM
Keyed straight spline, that is definately "NO FUN". Hate working on equipment with them on drivelines where you can be more brutal than on a steering wheel. They can be "challenging" sometimes.
