Serial #
11 replies to this topic
#1 greenmeanie OFFLINE
greenmeanie
  • 1 Thanks
  • 30 posts
Posted May 15, 2012 - 02:08 PM
Is there a way to tell the year from the serial number on a case 446?
446-79 /9769052
#2 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted May 15, 2012 - 05:21 PM
It is a 1979, I just looked it up on the Ingersoll Production chart.
  • greenmeanie said thank you
#3 greenmeanie OFFLINE
greenmeanie
  • 1 Thanks
  • 30 posts
Posted May 15, 2012 - 09:03 PM
Thanks
#4 Rick OFFLINE
Rick
  • 15 Thanks
  • 168 posts
Posted May 18, 2012 - 08:28 AM
Some af the case tractors have the year just after the model like yours 446-79.Some dont all mine dont so I have to do some research to find out.Hope this helps.
#5 A.C.T. OFFLINE
A.C.T.
    Another Classic Tractor
  • 2,364 Thanks
  • 2,496 posts
Posted September 01, 2012 - 03:22 PM
Tractor Data website is also helpfull.
1972: 9668002
1973: 9678031
1974: 9694673
1975: 9713265
1976: 9727857
1977: 9740617
1978: 9754759
1979: 9767590
1980: 9785820
1981: 14009950
1982: 14025407
1983: 14040936
1984: 14060091
1985: 14073621
1986: 14095530
1987: 1412151
1988: 14112874
#6 Mjoe7 OFFLINE
Mjoe7
  • 173 Thanks
  • 172 posts
Posted September 01, 2012 - 10:56 PM
1972: 9668002
1973: 9678031
1974: 9694673
1975: 9713265
1976: 9727857
1977: 9740617
1978: 9754759
1979: 9767590
1980: 9785820
1981: 14009950
1982: 14025407
1983: 14040936
1984: 14060091
1985: 14073621
1986: 14095530
1987: 1412151
1988: 14112874
It can be helpful, but I have found to many mistakes on there to even consider it.
Yes it's a 79.
#7 Moosetales OFFLINE
Moosetales
    Always learning something!
  • 1,088 Thanks
  • 1,284 posts
Posted October 10, 2012 - 12:25 PM
I have the flip side of the problem. I have a 1971 444 Case and the mower deck and tiller have no identifying information on them. No S/N or model number, or anything. How does one go about identifying the model or year in this situation?
#8 Cat385B ONLINE
    HAZMAT CAT
  • 14,007 Thanks
  • 10,013 posts
Posted October 10, 2012 - 01:00 PM
Posting tons of pictures of them. From lots of angles. Then we can start this dance:
'That's a J-44!'
'No, Fred; it's a H-40. I had three of 'em, I ought to know!'
'Nah, see that J-hook on top? They only had those on J-44's built on Tuesdays during the summer of '70!'
'Well, Fred; mine had that and it was an H-40.'
'Oh, you're right! I bought it from you, didn't I? Silly me!'
That's roughly how things are done around here. (although not so serious as that, sometimes)
Edited by Cat385B, October 10, 2012 - 01:06 PM.
  • Moosetales said thank you
#9 Mjoe7 OFFLINE
Mjoe7
  • 173 Thanks
  • 172 posts
If you have a operators or service manual or a planning guide from the year stated you could very carefully look at the details of the attachments and see if any match yours.
If you have the snap-fast pins and I believe you do then all snap-fast attachments will fit and work up until the four number designation Ingersolls. example 3000 series 4000 series 3016/4016.
I think the first snap-fast attachments started with a G or H. For example. 48" mower decks were H46 and as they changed them they would change the letter. J46, K46, L46, N46 and so on. I believe N would have been the last model number to work on a 3 digit tractor. 444 - 3 digits. the later ones started with SB and they were changed due to the rotation of the engines being different. The engines were turned 180 degrees causing the older attachments to spin backwards so all the attachments were reworked. The mower deck now threw grass out the right side of the deck not the left. I think you get the picture.
The only one that would look odd would be the L series attachments from 1984 as they were all painted Power White and are very hard to find.
1971-72 attachments were "H" lettered but you may have a newer attachment.
Another way is to post several detailed pictures on here and I can look through my manuals and see what we can come up with.
Edited by Mjoe7, October 10, 2012 - 01:14 PM.
#10 Moosetales OFFLINE
Moosetales
  • 1,088 Thanks
  • 1,284 posts
Posted October 10, 2012 - 07:14 PM
Thanks Mjoe7. Should I post the pics in the thread or start a new post?
#11 Moosetales OFFLINE
Moosetales
  • 1,088 Thanks
  • 1,284 posts
Posted October 10, 2012 - 07:16 PM
'That's a J-44!'
Thanks, Cat385B.
#12 Moosetales OFFLINE
Moosetales
  • 1,088 Thanks
  • 1,284 posts
Posted October 10, 2012 - 08:11 PM
Mjoe7,
I went ahead and posted pics of my attachments in my original thread in the Case forum; 1971 Case 444. Thanks for your input.
