Recoil Help
4 replies to this topic
#1 dogsoldier OFFLINE
dogsoldier
  • 361 Thanks
  • 509 posts
Posted May 15, 2012 - 12:06 PM
what is the best way to put the pull rope back into the recoil besides having someone else do it :laughingteeth:
here is what im working with
i have a couple thought but want to hear from others.
#2 olcowhand ONLINE
  • 42,507 Thanks
  • 31,838 posts
Posted May 15, 2012 - 07:29 PM
I take all remnants of rope out of the plastic pulley first. Then I wind the pulley until I have the spring almost to max wind, and then align the rope knot hole to the recoil housing rope hole. Lock the pulley in place, then feed the rope (end melted to a pointy end) through into the pulley, then with needle nose pliers, pull the rope up through, tie the knot & stuff the knot into the hole. BTW....I also put the handle on the other end of the rope before starting, as it's a pain if the pulley gets unlocked & zips all the rope into the housing!
  • dogsoldier said thank you
#3 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,163 Thanks
  • 1,331 posts
Posted May 15, 2012 - 07:50 PM
This guy is Canadian and the accent makes it a little hard to follow (just kidding folks).
Bill
#4 dogsoldier OFFLINE
dogsoldier
  • 361 Thanks
  • 509 posts
Posted May 16, 2012 - 05:18 PM
thanks for the ideas. i had thought of the way dan said but couldnt find a lighter since i dont smoke any more. i found one and now its back together, now to find a carb assembly for it.
#5 NUTNDUN OFFLINE
  • 10,350 Thanks
Posted May 18, 2012 - 07:45 AM
Glad to hear you got it together. Congrats on quitting smoking too.
