Carb?
3 replies to this topic
#1 tinbender7 OFFLINE
tinbender7
  • 1,115 Thanks
  • 784 posts
Posted May 14, 2012 - 09:37 PM
will a carb from a K321 work on a K341? My LGT did not have 1 of any kind and I have found 1 off a K321
#2 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted May 14, 2012 - 09:47 PM
Should work fine. What is the carb is it a Carter #28? or a Walbro
  • tinbender7 said thank you
#3 tinbender7 OFFLINE
tinbender7
  • 1,115 Thanks
  • 784 posts
Posted May 15, 2012 - 03:19 PM
it is a carter
#4 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted May 15, 2012 - 03:29 PM
I see they used the Carter #28 on the K341 also. If you look in the end of the carb that has the choke plate, the Number is stamped into the choke plate. more than likely it's a #28. The only difference on some of these is the mounting holes in the choke end for the air cleaner.
Good Luck!
