Trying Out My 314 And Brinly Box Blade -Update
brinly jd314 box blade
31 replies to this topic
#31 daytime dave ONLINE
  • 4,891 Thanks
  • 6,563 posts
Posted May 20, 2012 - 10:16 AM
Brian, you are doing a fine job. Lot's of hard work, but you sound like you have the problem identified and a solution in the works. Good job.
  • JDBrian said thank you
#32 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted May 20, 2012 - 11:22 AM
What I am thinking is you will most likely be doing a lot of the upkeep on this parking lot. Being able to pack the gravel in after grading could help keep it in place.
I am going to widen mine, just haven't decided whether to go to 46" or 48". I have metal to do it either way.
Kenny, I was sceptical about having a wider blade but after using this one I'm sure it could handle a wider blade at least for the type of work I was doing. In the Ford you have a low range which should give even more pulling power. Being able to cover the rear tire width with a couple of inches to spare would be a nice addition.
Also tagged with one or more of these keywords: brinly, jd314, box blade
