Ss/16 Maintenance - Rear End Oil?
9 replies to this topic
#1 motobreeder OFFLINE
motobreeder
  • 433 Thanks
  • 618 posts
Posted May 13, 2012 - 10:18 PM
I want to change the oil in the rear of the SS/16 I purchased recently.
I don't know when the last time was that the oil was changed.
What oil does it use?
I'm planning to use it for pulling in the summer and maybe pushing a plow in the winter.
  • 14,664 Thanks
  • 15,449 posts
Posted May 13, 2012 - 10:25 PM
Is this a MF or a Sears Gt?
  • MH81 and motobreeder have said thanks
#3 MH81 OFFLINE
  • 29,957 Thanks
  • 29,757 posts
Posted May 13, 2012 - 10:29 PM
My SS12 calls for 5 qts of SAE30, change at 500 hrs. I tend to go with a higher viscosity on rear ends with some miles on them, usually using 80-90 gear lube, however, you're a little further North & the lighter oil might be a good idea for the winter.
  • motobreeder said thank you
#4 MH81 OFFLINE
  • 29,957 Thanks
  • 29,757 posts
Posted May 13, 2012 - 10:30 PM
Didn't see the forum it was in, thanks Brian. Is this a Sears?
#5 motobreeder OFFLINE
motobreeder
  • 433 Thanks
  • 618 posts
Posted May 13, 2012 - 10:35 PM
Yes it's a sears.
Oops - can someone move this to the sears forum?
Too much time in the sun today.
#6 MH81 OFFLINE
  • 29,957 Thanks
  • 29,757 posts
Posted May 13, 2012 - 10:36 PM
No problem.
#7 motobreeder OFFLINE
motobreeder
  • 433 Thanks
  • 618 posts
Posted May 13, 2012 - 10:43 PM
My Moto-mowers use 80/90 weight oil. Using the same oil is helpful.
I'm planning to use the tractor for pulling this summer and maybe pushing a plow in the winter.
Definitely hard work in the summer. In the winter it will be in a garage that is above freezing.
Thanks for the really fast response.
#8 MH81 OFFLINE
  • 29,957 Thanks
  • 29,757 posts
Posted May 13, 2012 - 10:46 PM
The first winter I used it, it was cold with lots of snow. Didn't use it much, but did notice the stiffness a little. Since you're going to use it in the cold, maybe half-way in between, like a 50w?
Mine sleeps outside (sob) so it doesnt get any heat. I'm sure that'll help.
#9 Texas Deere and Horse OFFLINE
  • 14,664 Thanks
  • 15,449 posts
Posted May 13, 2012 - 10:50 PM
Yes it's a sears.
I was just checking, I got too much sun today myself.
#10 motobreeder OFFLINE
motobreeder
  • 433 Thanks
  • 618 posts
Posted May 22, 2012 - 12:27 AM
How do I put the oil into the transmission?
I'm missing something. I tried pouring it into the pipe behind the left-rear wheel but that put more oil on the outside than on the inside. There should be a vent/fill level hole.
Is it supposed to be pushed up from below - like a boat lower unit?
Thanks.
