White Lt-1650
11 replies to this topic
#1 gmagic911x OFFLINE
gmagic911x
  • 1 Thanks
  • 9 posts
Posted May 13, 2012 - 07:45 PM
2002 LT-1650 will not move forward or backward. Does this mean the hydrostatic transmission needs to be replaced?
#2 chris m ONLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted May 13, 2012 - 09:58 PM
I haven't found any info yet on this (not familiar with them)
But, have you checked the fluid level? and the drive belt? I don't know if yours has one but a plugged filter would do this to.
also was it acting funny, before it wouldn't move?
#3 gmagic911x OFFLINE
gmagic911x
  • 1 Thanks
  • 9 posts
Posted May 14, 2012 - 08:36 AM
Nothing funny before, but this occurred after the carburetor was rebuilt. The transmission is a closed system, so fluid can't be added and I don't think that there is any filter.
#4 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted May 14, 2012 - 10:28 AM
Did you check the disconnect lever to be sure it is moving correctly?
#5 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted May 14, 2012 - 10:32 AM
The drive belt could be a problem, or a linkage / belt tensioner problem. Axle keys can sheer off as well resulting in no drive at the wheel. Pulley on the input shaft of the hydro can come loose. Theres lots of things to try before writing off the transmission.
#6 gmagic911x OFFLINE
gmagic911x
  • 1 Thanks
  • 9 posts
Posted May 14, 2012 - 02:45 PM
The disconnect lever function looks ok. I'll take a closer look at the drive belt system.
#7 gmagic911x OFFLINE
gmagic911x
  • 1 Thanks
  • 9 posts
Posted May 15, 2012 - 07:44 AM
I have confirmed that the transmission drive belt is not broken and the transmission pulley is spinning while the engine is running. I'm back to my original thought that the hydrostatic transmission is the problem :confuse:
#8 gmagic911x OFFLINE
gmagic911x
  • 1 Thanks
  • 9 posts
Posted May 15, 2012 - 10:32 AM
I also confirmed that the throttle linkage to the transmission is functioning :mad2: .
#9 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted May 15, 2012 - 07:59 PM
Yes, the pulley may be spinning, but there are many times that the key or splines are stripped on the shaft, and the pulley is spinning loose on the shaft. Check this out to be sure.
#10 gmagic911x OFFLINE
gmagic911x
  • 1 Thanks
  • 9 posts
Posted May 17, 2012 - 09:22 AM
The transmission drive belt has been changed. It didn't fix the problem. All the other mechanicals (pulleys, linkages, etc.) are ok including the trans. engage/disengage function. I've concluded it's the transmission. The manual says it's sealed and requires no maintenance. However, I see a plug with an allen recess on top of the case. I've tried backing it out, but it woun't budge. I'm afraid I'll round out the recess.
#11 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted May 17, 2012 - 10:41 AM
If you jack up the rear wheels do you get any movement? Look at the axle and see if it's turning. If the axle key is stripped the axle will turn and the wheel won't. Unfortunately you may have reached the point where you need a new transaxle. Good luck with it.
#12 gmagic911x OFFLINE
gmagic911x
  • 1 Thanks
  • 9 posts
Posted May 18, 2012 - 12:11 PM
I was able to remove the fill plug and the oil level is ok. I jacked up the rear wheels and there is no movement when pushing the forward/rear pedal. I think the transmission has failed.
