Help Newby
mtdlt
11 replies to this topic
#1 frankreno OFFLINE
frankreno
  • 3 Thanks
  • 8 posts
Posted May 12, 2012 - 03:01 PM
How does my transmission work?
It started slipping and then stopped moving. The acre of lawn has not stopped growing and I need help.
Thank you in advance.
Frank
#2 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted May 12, 2012 - 03:15 PM
That is a mighty broad question! Most likely the slipping was caused by the "shift keys" jumping out of their place, due to plain old wear. If they wear off enough, or break their ends off completely....you go nowhere.
This is what they keys look like. They slide along grooves in the transmission shafts.
  • frankreno said thank you
#3 frankreno OFFLINE
frankreno
  • 3 Thanks
  • 8 posts
Posted May 12, 2012 - 03:25 PM
Where are these keys, how do I get to them and where do I buy new parts?
Can you also steer me to a manual/
Thank you,
Frank
#4 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted May 12, 2012 - 03:40 PM
To steer you to a manual, we would need the tractor model/serial, or the tag # on the transmission. Here's a link to a Tecumseh/Peerless manual to get you started maybe.
http://gardentractor...drive-products/
#5 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted May 12, 2012 - 04:50 PM
Welcome to GTTalk Frank. If you could supply more information about the tractor then there's a better chance of getting detailed help.
#6 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted May 12, 2012 - 05:47 PM
Welcome to GTt! Quick question for you. How is the drive belt? Is it possible your belt is worn and just slipping? Like stated above a little more info would help.
Good luck
#7 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,165 Thanks
  • 1,332 posts
Posted May 12, 2012 - 06:06 PM
How long was it slipping before it quit? Perhaps if it was only a short period you have sheared one of the axle to wheel keys. Again it would help if you could post the tractor information.
Bill
#8 caseguy OFFLINE
  • 1,629 Thanks
Posted May 12, 2012 - 08:34 PM
:wave: frankreno! Welcome to GTTalk! It sounds like the others will have your solution when you get them some more info, so I'm just gonna say hello and glad to have you here!
#9 MH81 OFFLINE
  • 29,979 Thanks
Posted May 13, 2012 - 08:10 AM
:welcome: to GTTalk, I agree that we need a little more info...
Make
Model
Any specifics about the problem, including weird noises or etc
I agree with all above.
Just a shot in the dark here, but I'm wondering if you have one of the MTD units that have the 6 or 7 position speed lever on the fender. If so, check to make sure the variable pullies are working properly. Also, these trannies can wear at the axel/case contact, as they have no bearings, only bushings. Once it's thru the bushings, the slop can cause the axels to tip and cause catastrophic damage internally when the gears slip past each other.
#10 frankreno OFFLINE
frankreno
  • 3 Thanks
  • 8 posts
Posted May 13, 2012 - 09:48 AM
Thanks to all! I purchased a new Ariens yesterday, lawn keeps moving! Will work on the MTD this winter.
This seems like a nice site.
Thanks
Frank
#11 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted May 13, 2012 - 10:18 AM
Get back with us when you do the teardown on the MTD. Sometimes, if a common trans, you can buy a new complete trans for $75 plus shipping. How bout posting a pic of your new ride?
#12 frankreno OFFLINE
frankreno
  • 3 Thanks
  • 8 posts
Posted May 13, 2012 - 05:11 PM
  • MH81 and caseguy have said thanks
