Shifter Question
4 replies to this topic
#1 backwoods OFFLINE
backwoods
  • 2,622 Thanks
  • 2,816 posts
Posted May 10, 2012 - 07:48 PM
so i was plowing out the fire pit with my 126 when it stuck in reverse i got it to its parking spot pulled the rear tin off and have removed the shifter. how do i remove the spring so i can rebuild the shifter?? anyone done this and pictures would help.
thanks
#2 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
Posted May 10, 2012 - 08:05 PM
You might be able to find something in the manual section, not sure what's there in the cub category. If not, somebody else might have a diagram for you. My cub 124 would jam into reverse, sometimes you could back up a steep hill and move the shifter around some and it would fall into neutral. Not long after jamming a few times my dad and I swapped out the entire transaxle for one with a creeper gear. I don't know if your problem is in the shifter or the slider gears, hopefully somebody can help you out.
#3 backwoods OFFLINE
backwoods
  • 2,622 Thanks
  • 2,816 posts
Posted May 10, 2012 - 08:10 PM
im thinking in just the shifter only because i can move the slider gears if the clutch is depressed.
#4 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
Posted May 10, 2012 - 08:18 PM
When you move them with your fingers do they "click" into position? I don't think it would make a difference if the clutch was pressed unless the engine was running.
#5 backwoods OFFLINE
backwoods
  • 2,622 Thanks
  • 2,816 posts
Posted May 10, 2012 - 08:26 PM
yea they click like they should. the shifter has a lot of play in it so that the only reason im leaning towards that.
