59 Chevy / Cummins -1
27 replies to this topic
#16 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted May 09, 2012 - 01:08 PM
It wouldn't hurt to adjust the bands since you're in there.
  • jdcrawler said thank you
#17 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 3,868 Thanks
  • 1,850 posts
Posted May 11, 2012 - 04:21 PM
This Cummins engine has a pair of vacuum pumps on it to power the vacuum power brake booster that was on the Dodge truck.
My truck has a hydro power brake booster that is run off the power steering pump so I won't need the vacuum for that.
I'm going to keep the vacuum pump though because I eventually want to put a cruse control unit on the truck and they are powered with a vacuum diafram.
Once I get a cruse control unit, it is going to need a vacuum reserve tank to hold a steady vacuum so I decided to go ahead and make that now.
I'm using an old propane torch tank like this to make the reserve tank out of.
The top of the tank has two valve ports in it.
I drilled both of these out and tapped them with a 1/8 NPT thread for hose fittings.
The other end has a thin steel cap on it so it has a flat bottom.
I removed the steel cap so the end is rounded and looks more like a vacuum reserve tank and not a torch tank.
I'll make up the mount for this tank once I figure out where it is going to be mounted.
The dowel pin problem has been corrected and the engine is all masked off and primed.
Here is the final engine color.
Once the paint is dry, the valve covers will be removed and painted Red.
Edited by jdcrawler, May 11, 2012 - 04:28 PM.
  • olcowhand and Mark 149 J. have said thanks
#18 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,162 Thanks
  • 1,331 posts
Posted May 11, 2012 - 04:41 PM
Ray,
As always great looking results. Maybe you'll be bringing the truck to Buckley and Boyne Falls this year?
Bill
#19 JDBrian OFFLINE
  • 9,601 Thanks
Posted May 11, 2012 - 05:09 PM
Awesome job on the engine Ray. That will look sweet in the engine bay of that 1 ton.
#20 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 3,868 Thanks
  • 1,850 posts
Posted May 11, 2012 - 05:59 PM
Ray, Maybe you'll be bringing the truck to Buckley and Boyne Falls this year?
Bill
Buckley for sure, Bill.
I don't think I'll be at Walloon Lake though.
#21 olcowhand ONLINE
  • 40,351 Thanks
  • 31,170 posts
Posted May 11, 2012 - 06:08 PM
Thanks for the torch tank idea Ray! Believe it or not, my 97 F250 has NO air reserve tank! Every time I go up a grade where the throttle opens, my vacuum drops off & my AC defaults to defrost. Sometimes I lose cruise control also. I've been aiming to go to the salvage yard to find a reserve tank, but I like your idea. I have an empty tank just like that one too! I can't believe how there wasn't a tank on my truck, but I've traced ALL the vacuum lines, and there isn't one.
#22 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 3,868 Thanks
  • 1,850 posts
Posted May 13, 2012 - 03:25 PM
The engine is ready to go in.
All I have to do now is wait for the engine to sell that is currently in the Chevy and then I can take it out and start putting the Cummins in.
  • superspeedex said thank you
#23 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted May 13, 2012 - 03:59 PM
That is one nice looking powerplant!!
#24 caseguy OFFLINE
  • 1,627 Thanks
Posted May 13, 2012 - 07:09 PM
That is looking great Ray! What did you use as a degreaser to clean up the engine?
#25 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted May 13, 2012 - 07:32 PM
Great looking engine Ray, keep it up, can't wait til you drop it into your truck.
#26 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 3,868 Thanks
  • 1,850 posts
Posted May 13, 2012 - 08:34 PM
I use Purple Power for degreasing things like this.
Don't use this degreaser on anything with good paint because it will dull the paint.
  • caseguy and Texas Deere and Horse have said thanks
#27 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted May 13, 2012 - 10:06 PM
That engine looks really nice Ray. Can't wait to see it in the 1 ton. thanks for the advice on the purple power!! :thumbs:
#28 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 3,868 Thanks
  • 1,850 posts
Posted May 22, 2012 - 03:05 PM
Pulled the truck into the garage this morning to get started on it.
I realize this photo doesn't show that much but this is the end result of about 5 hours of work.
The engine and transmission are all unhooked and ready to lift out.
First thing tomorrow, I'll bring the forklift in and take this engine out.
Edited by jdcrawler, May 22, 2012 - 03:13 PM.
