Hydro Pump Throwing Belt
5 replies to this topic
#1 frenchy OFFLINE
frenchy
  • 29 Thanks
  • 163 posts
Posted May 07, 2012 - 09:21 PM
I'm starting to notice that i'm being a bit of a post-whore on here... not intended, I just know where all the smart people are!
On my Dynamark/MF14, I've installed a power steering pump that i'm using for secondary hydraulics. (have posted about this before)
I'm still having issues throwing belts. On this note, I have a few questions:
1. Is it possible to have the belt too tight?
2. I have the belt in a figure 8. Should I have the pump offset at a slight angle to prevent the belt from rubbing on itself?
3. The pulley on the drive and the pulley on the pump are roughly the same diameter. Could that be just too much RPM for the pump, thus kicking the belt off?
Phew... that's all for now. I'm hoping that some thoughts might get me a few more things to try!
I'll try to get a picture of it up.
EDIT: Pic added.
Edited by frenchy, May 07, 2012 - 09:29 PM.
#2 chris m ONLINE
chris m
  • 3,311 Thanks
  • 4,044 posts
Posted May 07, 2012 - 11:03 PM
1st question YES, I have replaced many power steering pumps because the owners ran the belts to tight. the bearings can't take it.
2nd, Why the figure 8? The way it is on right now looks like it would be the problem
3rd, I wouldn't think the size of your pulleys would do it. the crank shaft pulley on a car is about the same OD as a pump pulley also.
Your biggest problem is that twist. Off setting wouldn't seem it would help. it might actually make it worse.
  • frenchy said thank you
#3 skyrydr2 ONLINE
  • 3,697 Thanks
  • 3,318 posts
Posted May 08, 2012 - 03:14 AM
The figure 8 in the belt is too close to the pullies . The belt needs distance to "relax" otherwise it will try to roll over in the pulley thus climbing out and coming off. You need to really turn the pump around.
#4 Alc ONLINE
  • 5,995 Thanks
  • 6,918 posts
Posted May 08, 2012 - 05:46 AM
Do you think a "double sided" V belt would work ,( one that has the "V" on both sides ) ? It wouldn't have to twist as much , I never used one myself but have seen them listed , Al
#5 olcowhand ONLINE
  • 37,208 Thanks
  • 30,212 posts
Posted May 08, 2012 - 09:01 AM
I totally agree. A cris-cross in a belt can't be that close to the pulleys. Turning the pump around is THE answer.
#6 frenchy OFFLINE
frenchy
  • 29 Thanks
  • 163 posts
Posted May 08, 2012 - 10:12 AM
Without multi-quoting the whole post... It sounds like I need to rotate the pump. ;)
Looks like I have another task on hand! Thanks all!
