Jd 116 -electric Pto For Deck Kills Motor
21 replies to this topic
#16 MH81 OFFLINE
Posted May 07, 2012 - 07:44 PM
I assume a new filter is in process? And I would keep running Seafoam assuming it does the trick.
#17 zolt OFFLINE
zolt
  • 10 Thanks
  • 90 posts
Posted May 07, 2012 - 09:10 PM
Thank you, Thank you----THERE IS A GOD!-----before i explain my sudden joy, i have to complete my story first,,,,, so after the seafoam additition, i waited a sufficient time block(watched the news, weather, NY and Washington game a bit, then out i went, again, changed fuel filter-just to be sure, then started it up again. this time it started about the same, then when i gave it a bit, just a bit, of throttle, ---dies.... repeat start,---again----slightest throttle----dies. so, of course i'm thinking----i actually made things worse,-then i glanced at the air filter box-----and EUREKA!!!, ----i started to loosen the nicely painted yellow retaining nut and yes, boys and girls, it started to run better and better.... so in a flash, i took the top off, hit the throttle and the briggs sprang to life like i knew it could.......
so now i must confess i feel really, really, how should i put it----hhmmm, i guess stupid is the right word....
and i must apologize, to those whose time i wasted, but also say...'you are welcome' to those that i have entertained....
my good mood has beeb spoiled though----the Rangers just tied the game with 6 seconds to go.....
i guess you(oops, i mean me) are/am never too old to learn---or remember......
must end with thanks to all who took time out-----with or without popcorn....
  • MH81 and chris m have said thanks
#18 chris m ONLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted May 07, 2012 - 10:48 PM
That's great news! Post back when you get a chance to run it through it's paces. And No apology needed!! As I see it you learned allot about your engine since 1st posting here. Just remember never think any question or problem is to stupid to ask for our help. We have all been there. This is how we learn! Good luck testing it out! I look forward to an update and some pictures would be nice :smilewink: :thumbs:
#19 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted December 06, 2012 - 03:26 PM
I believe it is your battery, take it out and take it to an auto parts store for a load test, they normally don't charge for that. You PTO put a big strain on the battery when you engage it and it the power isn't there it won't run.
Dick
#20 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,163 Thanks
  • 1,331 posts
Posted December 06, 2012 - 06:49 PM
Try pulling the choke out a bit before you engage the PTO and see if the engine keeps running or at least runs better/longer. That may help with determining if the problem is electrical or fuel although it does sound like fuel. But again with the wiggling the wire making a difference it is hard to tell.
Edited by GTTinkerer, December 06, 2012 - 06:51 PM.
#21 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted December 07, 2012 - 10:26 AM
From everything I have read I am going to say your battery could have a dead or weak cell. To check it properly, take it out and take it to just about any auto parts store and have a load test done one it. Most auto part stores do NOT charge for that service just hoping it is bad so they can sell you a new one.
Dick
#22 dave8338 OFFLINE
dave8338
  • 196 Thanks
  • 374 posts
Posted December 07, 2012 - 11:18 AM
His air filter was plugged, back in May. :smilewink:
