New Guy, First Tractor
1886 large frame bolens
192 replies to this topic
#166 hatedge OFFLINE
hatedge
    Beer Guzzling Canuck
  • 292 Thanks
  • 577 posts
Posted November 30, 2012 - 01:38 PM
Getting ready for winter :)
  • OldBuzzard, boyscout862 and Newpaws493 have said thanks
#167 boyscout862 ONLINE
  • 14846 Thanks
  • 9897 posts
Posted November 30, 2012 - 02:51 PM
Looks good. How is it running? What was the problem?
  • hatedge said thank you
#168 hatedge OFFLINE
hatedge
  • 292 Thanks
  • 577 posts
Posted November 30, 2012 - 06:34 PM
Still got the revving engine problem, I had to put the cab and chains on before we got too much snow for me to ride it down the hill to the barn where the cab was stored. It was hard getting back up the hill even with tha chains becaus the wheels kept spinning. I still cannot figure out the revving problem I have tryed everything I could think of and everything else you guys told me to check. I fix 2 stroke engines, fix my pick-up and my wifes minivan. For some reason I can pull my own when it comes to every other engines but this one :mad2:. I even tried adjusting the carb but it changes nothing. Now my carb is probably all messed up on top of it because ive been messing with the adjusment screws. The small engine shop is out of the question because Ive recently found myself on workers comp and I cannot afford it.
#169 KennyP ONLINE
  • 50110 Thanks
  • 52289 posts
Posted November 30, 2012 - 07:05 PM
Is there a possibility that the governor is messed up inside?
  • boyscout862 and hatedge have said thanks
#170 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted November 30, 2012 - 07:31 PM
Dang!!! That's a nice looking cab! :love:
Sure would like to have one like that for one of my diesels.
#171 boyscout862 ONLINE
  • 14846 Thanks
  • 9897 posts
Posted November 30, 2012 - 08:25 PM
The wheel weights may not be enough, especially once the blower is on. You may need to put a big weight on the rear hitch.
KennyP has a good point. Check the governor. The first thing is to see if any of the linkage pieces are loose. Do you have the engine manual? Carefully review the section on the governor to see how to adjust it.
It has been so long now I don't remember if this ever ran right for you. If it did, maybe something got knocked loose when working on it. I'm going to read through the engine manual for awhile tonight and see if I can figure it out. It would be so easy if you lived nearby, I'd just drive over with my test equipment.
Please describe the reving problem.
Edited by boyscout862, November 30, 2012 - 08:27 PM.
#172 boyscout862 ONLINE
  • 14846 Thanks
  • 9897 posts
Posted November 30, 2012 - 11:30 PM
I used my old manual but realized that you were probably using http://gardentractor...service-manual/ . Page 1.4 has the troubleshooting guide. Most likely: carb adjustments which are shown on page 4.1 & 4.2. It gives the initial adjustments to use. Other possibilities are carb clogged( there is a good description of carb rebuilding in the kohler manuals section), spark plug gap too small, vacuum leak. Old or dirty gas could cause the problem too. Good Luck
#173 hatedge OFFLINE
hatedge
  • 292 Thanks
  • 577 posts
Posted December 01, 2012 - 10:57 PM
Nah not the governor, the revvin comes from wrong air fuel mix (I think)
#174 hatedge OFFLINE
hatedge
  • 292 Thanks
  • 577 posts
Posted December 01, 2012 - 10:58 PM
Wouldn mind makin one for ye if you could get me in the States lol
Edited by hatedge, December 01, 2012 - 11:00 PM.
#175 hatedge OFFLINE
hatedge
  • 292 Thanks
  • 577 posts
Posted December 02, 2012 - 01:39 AM
I did try all them adjustments, Thanks, and carb has been cleaned twice already. Gonna look in the float adjustment now
#176 hatedge OFFLINE
hatedge
  • 292 Thanks
  • 577 posts
Posted December 02, 2012 - 01:44 AM
It did run right all summer then started to miss and rev then the gas pump died. Adjusting the governor implies thst it is already all oiginal parts!!! I personnally cant garanty that
#177 hatedge OFFLINE
hatedge
  • 292 Thanks
  • 577 posts
Posted December 04, 2012 - 06:10 AM
I have found a lice lil tractor for my brother. it needs a new engine but its pretty nice and it has all the equipment. Now I have a contract to rebuild it next spring, to think I cant even get mine going right!!!
This is not an actual pic of the tractor but its the same model MF 12images.jpg
#178 mjodrey OFFLINE
  • 2373 Thanks
  • 13481 posts
Posted December 04, 2012 - 06:13 AM
Yes,that is a nice looking cab.
#179 KennyP ONLINE
  • 50110 Thanks
  • 52289 posts
Posted December 04, 2012 - 07:37 AM
The reason I suggested the governor is that my Cub lost the governor gear inside. Took a while to figure out what was causing the problem. Put a new gear in it and it runs good again.
#180 hatedge OFFLINE
hatedge
  • 292 Thanks
  • 577 posts
Posted December 04, 2012 - 07:30 PM
Yeah I tought that governor was the problem since its the one revving the engine, but last night I realised that I have an air leak in the gas line and also have to reajust the float in the carb. the problem might soon have a solution and I had a tractor mechanic look at the governor for a couple minutes as a favor to me and he pointed the gas line and the probable float problem to me. So on I go to reajust everything and see if trouble is fixed
Also tagged with one or more of these keywords: 1886, large frame, bolens
