The exhaust and all the wires and hoses are removed and the engine is ready to lift out of the Dodge.
Here she comes up and over the radiator support.
Setting down on the stand so it can be cleaned up and painted.
There are plastic bags fastened over both ends of the turbo so nothing gets into it.
The rear crankshaft seal looks like it has been leaking a little so that is getting replaced now.
While the transmission is off, I'm going to replace the trans filter and both seals.
I'm also removing the timing gear cover and make a locking tab for that dowel pin that has worked loose on some engines.
The front crankshaft seal will get replaced before I re-install the gear cover.
The water pump isn't leaking but I'm going to put on a new one anyway simply because this one is 22 years old.
