Cub Cadet 1250 Hydro, Need Help!
4 replies to this topic
#1 wheelhorse2 OFFLINE
wheelhorse2
  • 4 Thanks
  • 22 posts
Posted May 02, 2012 - 10:11 PM
I recently picked up a Cub 1250, a newer version, because it has the automatic relese for the hydro. However, i have an issue, because the shift lever will not budge, and i do not want to force it. The brake is off, but the pedal sits lower than it should, like its missing a spring? what can i do to unseize the shift lever, so i can be able to drive this thing. Thanks!
#2 bgkid2966 OFFLINE
bgkid2966
  • 1,412 Thanks
  • 1,331 posts
Posted May 02, 2012 - 10:15 PM
Will the shift lever move if you hold the brake pedal all the way up?
Geno
#3 Kyocum OFFLINE
Kyocum
  • 299 Thanks
  • 424 posts
Posted May 02, 2012 - 11:01 PM
I would take the tunnel cover off first and see what you got going on under there. You can see most all of the linkage for underneath the cover. A couple pics of underneath the cover would be helpful also.
#4 pattonacres OFFLINE
pattonacres
  • 105 Thanks
  • 46 posts
Posted May 03, 2012 - 08:57 AM
you need to un hook some linkage and narrow down where the problem is.if its froze or jammed no use trying to move it all at once.narrow down the problem
#5 Cvans ONLINE
  • 7,306 Thanks
  • 6,390 posts
Posted May 03, 2012 - 09:42 AM
Your going to have to get that brake pedal all the way up before you can get the hydro control to move. I just went through this with my 1450.
