Converting Slides And Pictures To Digital
23 replies to this topic
#16 bgkid2966 OFFLINE
bgkid2966
  • 1,412 Thanks
  • 1,331 posts
Posted May 03, 2012 - 08:45 AM
My scanner is a stand alone for doing just slide/negatives. It does not have any software to mess with. It scans direct to a memory card and then just transfer into pc.
Geno
  • HowardsMF155 said thank you
#17 HowardsMF155 ONLINE
  • 2,968 Thanks
  • 3,018 posts
Posted May 03, 2012 - 08:46 AM
have you tried scanning them? some scanners are able to copy slides and/or negitive strips, they have a holder for them.
a good old program for editing them is 20/20 from http://www.sofotex.c...nload_L230.html
it is free to download and use. I have been using it from around 1990 and it is still one of the best out there.
it can take slides (negitives) and change them into positives
Do you know what the resolution is?
#18 HowardsMF155 ONLINE
  • 2,968 Thanks
  • 3,018 posts
Posted May 03, 2012 - 08:47 AM
Geno
Can you tell me what model it is?
#19 bgkid2966 OFFLINE
bgkid2966
  • 1,412 Thanks
  • 1,331 posts
Posted May 03, 2012 - 11:19 AM
It is a Wolverine F2D. I have had it for a couple of years and finally got started on the project. Here is a link to it on Amazon: http://www.amazon.co...36061862&sr=8-1
I hope this helps, there are more models of them there also.
Geno
#20 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted May 03, 2012 - 11:27 AM
I have had a couple of Visioneer scanners that had a slide attachment.
Let me check on the suggested resolution.
#21 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted May 03, 2012 - 11:32 AM
Check page 24 they suggest starting at 1200 dpi and 2700dpi for best results.
http://support.visio...tall.OT3.EN.pdf
#22 HowardsMF155 ONLINE
  • 2,968 Thanks
  • 3,018 posts
Posted May 03, 2012 - 08:40 PM
Good info there ducky, thanks
#23 lyall OFFLINE
lyall
  • 2,227 Thanks
  • 1,593 posts
Posted May 03, 2012 - 10:28 PM
remember the higher you set the dpi (dots per inch) the more disk or memory is used.
using the higher setting only if you need to make a larger print out - like poster size.
#24 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted May 04, 2012 - 04:45 AM
Good thought lyall. Also just scan only the area you need to hold down that memory usage not the whole scanner bed surface.
