Steering Wheel
18 replies to this topic
#16 Alc ONLINE
  • 6,742 Thanks
  • 7,396 posts
Posted May 10, 2012 - 10:43 AM
Glad you didn't have a big 3/4" inpact and break off the splined shaft , ,that's what I was worrying about when I looked at the steering wheel up close , Al
#17 dacheez17 OFFLINE
dacheez17
  • 7 Thanks
  • 25 posts
Posted May 10, 2012 - 08:29 PM
yup, me too, not only do I not have one of the big impacts, I don't have the correct air compressor to do the job either. If I have to pull lug nuts, it takes me a min to do it. I have to wait for the compressor to power up, then hit it, then wait again. LOL, oh well I'll add it to my Bday, xmas, and daddy's day present. :laughingteeth:
#18 dacheez17 OFFLINE
dacheez17
  • 7 Thanks
  • 25 posts
Posted May 11, 2012 - 09:43 PM
ok, so I can't seem to get the splined piece off of the steering stem. I've used channel locks, hitting them upward with a hammer, I've used a cold steel chisel, and a punch, trying to hammer up. This thing isn't budging. I'm not sure what else I can do, I do have a propane torch I can try to heat it up a bit, but propane won't heat it up enough I believe. Does anyone have any ideas on trying to remove this thing?
#19 Ryan313 ONLINE
  • 3,364 Thanks
  • 5,229 posts
Posted May 11, 2012 - 09:56 PM
I assume you got the nut off, yes? You could try putting a pulley-puller on it. Leave the puller on over night, spray it with some penetrating oil or something similar a few times and see if the puller takes it off. If not, you can put tension on it and GENTLY hit the splined part with a hammer. I would only do this as a last resort, the steering box in these tractors can break VERY easy. If you break the aluminum case it is very expensive to replace it.
