My Ford Yt 16H And Need Help
10 replies to this topic
#1 dogsoldier OFFLINE
dogsoldier
  • 361 Thanks
  • 509 posts
Posted May 01, 2012 - 09:01 AM
i went out last nite and gave the guy money towards the tractor. here are a couple pics i took with my droid phone ( will get better pics when i get it home ).
now for my question:
while i was there we tried to move it, i reached under the tractor and was trying to find the relief valve and thought i found it but when we tried to move it ,it wouldnt move. i looked thru all the pdf's for the tractor and couldnt find anything for it. could someone post a pic of where it is so when i go back out to get it i can release the pressure and we can push it onto a trailer.
#2 daytime dave OFFLINE
  • 4,963 Thanks
  • 6,596 posts
Posted May 01, 2012 - 09:37 AM
In your second photo, on the left of the steering wheel on the dash, there is a T handle. You pull it out and turn or twist it. If it isn't frozen or rusted, it should pull the lever.
If not, the relief lever is just ahead of the rear wheel on the right side of the tractor, underneath.
#3 Russ OFFLINE
Russ
  • 131 Thanks
  • 367 posts
Posted May 01, 2012 - 10:15 AM
Sorry I can't help ya any but just wanted to say that ya got a nice tractor setting there,,, :thumbs:
#4 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
Posted May 01, 2012 - 10:37 AM
Sorry, I can't help your question much. Im looking forward to seeing more pics of it! Good luck!
#5 dogsoldier OFFLINE
dogsoldier
  • 361 Thanks
  • 509 posts
Posted May 01, 2012 - 04:24 PM
thanks dave, the T handle pulls out but im not sure if its connected underneath or not. thats why i was wondering what the relief lever looked like so i could look at it and make sure its on there. i looked on line but cant find anything.
Russ and Ryan..... thanks, i cant wait to get it home.
#6 KennyP OFFLINE
  • 40,881 Thanks
  • 47,091 posts
Posted May 01, 2012 - 06:04 PM
I went all through the manuals I have for the YT and all I found was the knob needed to be pulled out and turned clockwise to lock. Couldn't see anything else about it.
  • dogsoldier said thank you
#7 daytime dave OFFLINE
  • 4,963 Thanks
  • 6,596 posts
Posted May 01, 2012 - 07:11 PM
Dog Soldier
The best I can do is take a photograph of mine on Thursday. It's at Dad's place and I won't be there till Thursday. PM me Wednesday night if you still need the photograph.
#8 dogsoldier OFFLINE
dogsoldier
  • 361 Thanks
  • 509 posts
Posted May 02, 2012 - 02:27 AM
Kenny and Dave thanks,
when i go back out this weekend ill try to pull it out and turn the T handle . dave that would be great just in case it wont work i can get under it and turn by hand.
#9 daytime dave OFFLINE
  • 4,963 Thanks
  • 6,596 posts
Posted May 03, 2012 - 08:58 PM
dogsoldier
I just got home. Here you go.
It is the triangular shaped piece of metal that pivots.
I tried to keep the piece centered in the photographs. If you look, you can see where I took out the end of the pull and turn wire that goes to the dash. In the last picture, I am pushing the the piece towards the front of the tractor. I used a set of vice grips to hold it forward while I pushed. You may be able to just duct tape it.
Let me know if you need anything else. I hope it helps you.
Edited by daytime dave, May 03, 2012 - 08:59 PM.
  • KennyP and dogsoldier have said thanks
#10 dogsoldier OFFLINE
dogsoldier
  • 361 Thanks
  • 509 posts
Posted May 04, 2012 - 06:00 AM
great pics dave , thanks
that should help a lot. when i was reaching under the other day i was looking and feeling for something totally different.
#11 KennyP OFFLINE
  • 40,881 Thanks
  • 47,091 posts
Posted May 04, 2012 - 06:10 AM
That sure helps figure things out, Dave! I wouldn't have figured it out. Thanks!
