Jd F935 Water Pump
23 replies to this topic
#16 KennyP ONLINE
  • 40,154 Thanks
  • 46,773 posts
Posted May 02, 2012 - 12:02 PM
Glad you got it going your way, Daniel. About time, huh?
#17 olcowhand ONLINE
  • 42,412 Thanks
  • 31,804 posts
Posted May 09, 2012 - 10:28 AM
Well, things took a bad turn. The guy said these pumps press apart easily, but mine was seized good & tight. I barely pressed at all and the pump body busted. I even asked him if the pump body is plenty strong & he assured me "no problem". I am cleaning the parts to see if I can TIG it back together, but if it's not good, then I'll be laying out $268 plus tax at my local JD dealer.
#18 Alc ONLINE
  • 7,126 Thanks
  • 7,530 posts
Posted May 09, 2012 - 10:31 AM
Sorry to hear that it broke , hope you can salvage it by welding , Al
#19 olcowhand ONLINE
  • 42,412 Thanks
  • 31,804 posts
Posted May 09, 2012 - 11:55 AM
The welding isn't pretty, but I "think" it may be a good enough weld. Luckily it didn't break in the shaft seal area. I'll post a pic later.
#20 olcowhand ONLINE
  • 42,412 Thanks
  • 31,804 posts
Posted May 09, 2012 - 03:08 PM
It's been a long tedious day, but at this point, it looks like I have pulled the pump through. The welds will look pitiful to a pro, but for me, they look halfway decent! lol
Anyway, this is it. On the inside, you can see where it broke. This entire section went flying across the shop floor. Talk about a sinking feeling in your stomach! But it's welded now.
Here is the outside only weld.
And here she is running, just a still shot, but you can see the fan is turning.
It had a small leak from underneath on the body, but I couldn't see from where. So I put some Bars stop leak in her & went mowing. No leak at all now. Time will tell the tale whether she'll restart the leaking or not. Right now I'm stressed out a little bit, but starting to chill somewhat. Time to go feed the cows.
#21 olcowhand ONLINE
  • 42,412 Thanks
  • 31,804 posts
Posted May 09, 2012 - 08:42 PM
Mowed some more & still no leaks. Keeping my fingers crossed on this one! I did some more servicing on this machine tonight with the help of my 2+yr old Grandson. He had a great time "working" on it!
#22 Alc ONLINE
  • 7,126 Thanks
  • 7,530 posts
Posted May 09, 2012 - 09:00 PM
Glad to see everything turned out well :thumbs: Al
#23 Texas Deere and Horse OFFLINE
  • 14,863 Thanks
  • 15,511 posts
Posted May 09, 2012 - 10:01 PM
Daniel, Sorry for your problems, but glad you were able to get it welded up.
#24 KennyP ONLINE
  • 40,154 Thanks
  • 46,773 posts
Posted May 10, 2012 - 05:01 AM
Looks like a fine job from here, Daniel. Hope it holds for a long time
