Homemade Sleeve Hitch For Mf10
18 replies to this topic
#16 JDBrian OFFLINE
  • 9,642 Thanks
  • 14,157 posts
Posted April 29, 2012 - 10:27 AM
Try it and see if it does the job. If so, then no more work is needed. If you are raising and lowering it by hand the leverage of the lift linkage (chains) may be an issue.
#17 johnboggs21 OFFLINE
johnboggs21
  • 18 Thanks
  • 184 posts
Posted April 29, 2012 - 12:36 PM
Well it sort of works. It doesnt lift high enough, and doesnt go low enough lol. The lever moves quite a distance before I get any movement out the back of it. I think once I get the slop out of it, it will work great.
#18 olcowhand ONLINE
  • 42,362 Thanks
  • 31,791 posts
Posted April 29, 2012 - 01:54 PM
You really don't need down pressure if implements are adjusted right, plus down pressure is almost pointless on small GT's, as they are so light that when you apply down pressure, you just lose traction right when you need it most. And like's been said, move the chains back further on the lower hitch. This will give higher & lower movement.
#19 johnboggs21 OFFLINE
johnboggs21
  • 18 Thanks
  • 184 posts
Posted April 30, 2012 - 09:23 AM
Ill have to try that next time I have some free time. Ive been mentally designing a front blade and snowblower for this thing too lol
