Massey Furguson 1655
This topic has been archived. This means that you cannot reply to this topic.
6 replies to this topic
#1 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted April 27, 2012 - 04:12 PM
http://oneonta.craig...2962898426.html
#2 glgrumpy OFFLINE
  • 8,362 Thanks
  • 7,747 posts
Posted April 27, 2012 - 11:50 PM
Well, sounded cheap! 20hp must be bigger physically than 16? He sure whacked out the hood!
#3 olcowhand OFFLINE
  • 38,812 Thanks
  • 30,704 posts
Posted April 28, 2012 - 12:51 PM
Must be an Onan CCKB, as they are 19.9hp. Yes, they are bigger, and much heavier than the stock engine. Cast iron block, steel rods, cast intake & exhaust. The crank position is much higher too, but not a problem for driving the hydro, or to drive the deck, as you'd just use longer belts. But notice he only points out "FRONT" pto. With the crank position so high, I doubt very much that the rear pto shaft can be used.
#4 JDBrian OFFLINE
  • 9,599 Thanks
Posted April 28, 2012 - 02:45 PM
Those are a nice tractor. Did they come with a 16 single or a twin? Maybe i'm thinking of the 1650 that was a K341. I like the belt drive setup myself. It's easy to maintain and gives some shock protection to the drivetrain.
#5 olcowhand OFFLINE
  • 38,812 Thanks
  • 30,704 posts
Posted April 28, 2012 - 02:47 PM
Yes, the 50 series used the Kohler K singles, while the 55 series used the twin Onan. I prefer the direct drive like the 50 series used. The hydro itself has built in shock protection pretty much.
#6 JDBrian OFFLINE
  • 9,599 Thanks
Posted April 28, 2012 - 02:58 PM
I forgot about them being hydro! That's another advantage of hydros! Self limiting under a shock load.
  • 14,665 Thanks
  • 15,449 posts
Posted April 28, 2012 - 03:18 PM
It's gone now, must have been a real deal.
