210 Trans Questions
4 replies to this topic
#1 whjoel OFFLINE
  • 7 Thanks
  • 52 posts
Posted April 26, 2012 - 06:51 PM
Looking for info on disassembly of a trans for axle shaft replacement on a 210. Preferably a manual I could download. It belongs to a buddy of mine and I was elected to help because his normal helper costs him too much money when he helps...if you know what i mean. So Im hoping to help him out without causing the problems his other helper usually does! Haha Any help would be appreciated.
#2 Trav1s ONLINE
  • 3,412 Thanks
  • 4,434 posts
Posted April 26, 2012 - 09:14 PM
Here is a peerless transaxle manual
  • GTTinkerer said thank you
#3 1971Deere OFFLINE
  • 48 Thanks
  • 66 posts
Posted April 26, 2012 - 09:30 PM
The manuals are also available on this site in the manual section.
#4 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted April 27, 2012 - 05:03 AM
You can also access parts diagrams at JDParts.com. Just do a model search for 210.
#5 guglielmo69 OFFLINE
  • 12 posts
Posted April 29, 2012 - 08:35 AM
make sure the splines for the hubs are clean so they will slide back through the bearing. I hit my axel with a dead blow hammer to drive it bach through and it shifted and busted the thrust washer.I was just replacing axel seals and that mistake made me have to split the trans in two to to replace the thrust washer. the second side i used my big two jaw puller like I should have did the first time. Some time learning from some body elses mistakes is easyer and cheaper than learning from your own.
