* * * * * 1 votes
B10 Restoration
105 replies to this topic
#91 achomesteader OFFLINE
achomesteader
    GT Fanatic
  • 867 Thanks
  • 2,231 posts
Posted August 23, 2012 - 04:34 AM
All the work you have put in has really paid off Dan! It looks great! :orangecool:
  • DanP said thank you
#92 DanP ONLINE
DanP
  • 324 Thanks
  • 485 posts
Posted August 26, 2012 - 12:01 AM
What a day. I spent all morning hauling stuff down to our show. I still had work to do on the B10 so I dedicated the afternoon to working on it. I have it all back together but it wont start. I told myself check all the simple things first. So I did, no luck. Then I decided that since it would not start and I was getting blow back in the carb it had to be timing. I pulled the motor out and took the shroud off and re timed the mag. I checked the points and re adjusted them, nothing was off much but I had to check. Put it back in the mower and hit the started expecting it to fire, no luck. Ok so did I not get the timing marks lined up? I could take the side cover off the motor with it in the frame and I checked, it was timed right. Now what? So I double checked the carb and found everything open and working fine. Then I wanted to check the valves so I took the cover plate off and checked the clearance 8 and 18 just what the book called for. So I decided if I sat and stared at it long enough I would figure it out. No luck so I called a friend of mine and asked him to come over. We went over what I had done and he said it has to be valves because it is blowing back through the carb. So off with the valve cover again, then off with the head. He thought the intake was not closing soon enough and wanted to take a few thousands off the valve. Now if you have ever taken the valves out of a B&S 10HP you know what a pain those keepers are. It is hard enough on the bench let alone in the GT. But we took it out and ground a little off the valve. We spent the next hour putting those little keepers back in. Then put it all together and tried to start it. No luck same thing. Now keep in mind we did all this to a motor that has been painted and clear coated. We both were stumped, what could be wrong? I turned it over on more time and both of us were watching the flywheel turn and looked up at each other at the same time and said, "it is going the wrong direction". DUH!!! I had bought the starter generator from a Simplicity dealer and he said it came off a B10 and would work. He never said what direction it would work. My friend said he had a starter laying around at home and went to get it. We put it on turned the motor over one time and it started right off. 10 hours later my B10 was running. A little carb adjusting and it was purring just fine. I guess that was one of the simple things I forgot to check.
So I put all the side panels on and got the hood to fit and put the mower deck on. Some touch up on the paint and tomorrow it will be ready for some pictures. Now what do I give this guy for all his help. I owe him big time except for making me take that valve out with those stupid keepers.
I hope to have pictures posted tomorrow if the weather is nice.
#93 KennyP ONLINE
  • 38,284 Thanks
  • 45,886 posts
Posted August 26, 2012 - 12:10 AM
Dan, that sounds like something I'd go through. Glad you finally got it figured out. They don't seem to want to work so well going backward. All I can say about the friend is be there when he needs help!
#94 DanP ONLINE
DanP
  • 324 Thanks
  • 485 posts
Posted August 26, 2012 - 08:57 AM
Here are a few pictures. I will take more and better ones when I can get it outside. It is raining this morning.
  • johndeereelfman and goodnews have said thanks
#95 KennyP ONLINE
  • 38,284 Thanks
  • 45,886 posts
Posted August 27, 2012 - 06:29 AM
That is great, Dan! Looks better than new!
#96 DanP ONLINE
DanP
  • 324 Thanks
  • 485 posts
Posted August 28, 2012 - 07:31 AM
I got up early to take some pictures in the morning light. It is now completed and I want to thank everyone that helped me out with information or parts. Johndeereelfman helped me with a lot of missing parts and that made the restoration much easier. I have 142 hours in it plus the time for research and who knows how much time I spent on that.
This is a great site and everyone is so helpful, what a great hobby. Thanks.
#97 Canawler OFFLINE
Canawler
  • 1,948 Thanks
  • 1,802 posts
Posted August 28, 2012 - 07:55 AM
Looks awesome :thumbs:
But are they really ever "completed" :confuse:
#98 KennyP ONLINE
  • 38,284 Thanks
  • 45,886 posts
Posted August 28, 2012 - 08:15 AM
Great job! Well done! Now to get it dirty! :bigrofl:
#99 jdslednut OFFLINE
jdslednut
  • 678 Thanks
  • 851 posts
Posted August 28, 2012 - 08:22 AM
It sure looks great!
#100 cookiemonster OFFLINE
cookiemonster
  • 409 Thanks
  • 1,274 posts
Posted August 28, 2012 - 08:37 AM
Sure does. Always liked that model/year of tractor.
#101 achomesteader OFFLINE
achomesteader
    GT Fanatic
  • 867 Thanks
  • 2,231 posts
Posted August 28, 2012 - 08:54 AM
It's a beauty Dan! :thumbs:
#102 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted August 29, 2012 - 04:22 PM
Your tractor really turned out nice Dan. Great job! After all that time and money spent to get it complete, now is the time to sit back and enjoy it. Can't wait to see it listed as Tractor of the Month!
#103 goodnews OFFLINE
goodnews
  • 126 Thanks
  • 423 posts
Posted August 29, 2012 - 07:08 PM
wow!!!!! now that a 100% resrore great job you have the right to bragg . in Christ
#104 B10Dave OFFLINE
B10Dave
  • 779 Thanks
  • 348 posts
Posted September 18, 2012 - 07:30 PM
Great job Dan. Has to be one of the nicest B10's I have ever seen. You should get years of fun and enjoyment from it. Dave
Edited by B10Dave, September 18, 2012 - 07:30 PM.
#105 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted September 18, 2012 - 07:42 PM
That looks great! It was great to follow this thread!
