* * * * * 1 votes
B10 Restoration
105 replies to this topic
#61 MH81 OFFLINE
Posted July 11, 2012 - 10:47 PM
I found out the name, but no pictures... It's called Caswell Copy Chrome. Might be worth looking into.
  • DanP said thank you
#62 MH81 OFFLINE
Posted July 12, 2012 - 05:05 PM
George found the article for me.
http://gardentractor...in-your-own-r63
#63 DanP OFFLINE
DanP
  • 324 Thanks
  • 483 posts
Posted July 13, 2012 - 07:25 PM
I got my tires mounted today and I will get them on this weekend. Hope to get the motor back together this weekend also.
#64 MH81 OFFLINE
Posted July 13, 2012 - 07:34 PM
Boy do those look good!
#65 cookiemonster OFFLINE
cookiemonster
  • 409 Thanks
  • 1,274 posts
Posted July 13, 2012 - 09:48 PM
Nothing beats a new set of wheel skins. Can't wait to see it all together.
#66 KennyP ONLINE
  • 37,426 Thanks
  • 45,465 posts
Posted July 14, 2012 - 02:41 AM
Those tires/wheels look great! Gonna be nice to have it back on the ground again!
#67 DanP OFFLINE
DanP
  • 324 Thanks
  • 483 posts
Posted July 14, 2012 - 04:21 PM
Well I got the tires on the GT today. Put the rear ones on backwards fist then turned them around. Much more clearance by the frame that way. Spent a good part of the day sanding the parts getting them ready to go back to the chromer. I can see why it cost so much to prep the stuff. You have to go from 60 grit to 120, 220,320,400. That takes a while. I got it up to the 400 and will get that done tomorrow. Here is a couple shots of the GT with the new tires on.
#68 KennyP ONLINE
  • 37,426 Thanks
  • 45,465 posts
Posted July 14, 2012 - 04:42 PM
Nice to have a rolling chassis again, huh? Keep up the good work!
#69 DanP OFFLINE
DanP
  • 324 Thanks
  • 483 posts
Posted July 15, 2012 - 07:49 PM
Spent most of the day working on it again. I finished sanding the parts to be chromed down to 400 grit then packaged them up ready to go back to the chromer Monday. I finished the deck and got it all back together other than the rollers. They are rubber so I painted them with Miller's tire paint and when they dry I will put them on. Then I did some touch up on the wheels after the tire guy mounted them. It is almost impossible not to to scratch those rimes when mounting tires. Then I started on the motor and got a lot of put back together. I forgot what a pain in the a$$ those valve keepers are to get in. The 2 piece tapered kind. No room for your fingers in there. I did finally get them and decided to quit for the day. I got a different coil and I am going to have to figure out how to wire it as it is different than the old one. I have to rebuild the carb and then it is just putting things back together and paint.
#70 MH81 OFFLINE
Posted July 15, 2012 - 08:11 PM
Won't be long now till you can hear it run... and yes, those keeps are a PITA
#71 cookiemonster OFFLINE
cookiemonster
  • 409 Thanks
  • 1,274 posts
Posted July 15, 2012 - 09:31 PM
This will be a better finish than new, no doubt.
#72 KennyP ONLINE
  • 37,426 Thanks
  • 45,465 posts
Posted July 16, 2012 - 06:12 AM
Looking good, Dan! Something to be very proud of when you get it all back together.
#73 goodnews OFFLINE
goodnews
  • 126 Thanks
  • 423 posts
Posted July 17, 2012 - 06:20 PM
wow! great job Dan i see alot of kowledge and patience in your in your work !!! 1st John 1:7
#74 Ryan313 OFFLINE
  • 3,360 Thanks
  • 5,228 posts
Posted July 17, 2012 - 06:47 PM
Looks Great! It looks pretty good as a rolling chassis! It will be even better once it is finished!
#75 DanP OFFLINE
DanP
  • 324 Thanks
  • 483 posts
Posted July 29, 2012 - 07:19 PM
I got the motor all back together and painted this weekend. Now it is back in the frame. Now just waiting for the chrome parts.
