* * * * * 1 votes
B10 Restoration
105 replies to this topic
#16 DanP ONLINE
DanP
  • 324 Thanks
  • 485 posts
Posted May 05, 2012 - 03:15 PM
Worked about 6 hours on it today. Sandblasted the frame, man that is some hard paint to get off. Then I put new bearings in the mule drive and took the tires off the wheels. I worked on getting some of the dents out of the fenders. I ran out of blasting material so I have to get some more before I can finish. It is supose to rain tomorrow so I don't think I will get much sandblasting done.
#17 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted May 06, 2012 - 05:23 PM
Dan, are these the pieces you're looking for?
Oh, I removed the arm rest pads, and tried cleaning up the chrome a little. Will still need re-chromed, but at least it looks better than it did before!
Let me know what you want.
#18 DanP ONLINE
DanP
  • 324 Thanks
  • 485 posts
Posted May 06, 2012 - 06:47 PM
Yes that is the right pulley. I already have those belt guides, I will have to see if I can find a picture of what I am talking about. I sent you a PM
I did some more sandblasting today and then primed a few parts. It was hot under that hood. This thing is going to be a pain to paint with all those little parts. I can't put it all back together as I wont be able to get all the parts covered.
Edited by DanP, May 06, 2012 - 06:49 PM.
#19 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted May 07, 2012 - 07:38 PM
Sounds good Dan, I'll get everything together. Let me know if you come up with anything else that you might be needing.
Edited by johndeereelfman, May 08, 2012 - 05:50 AM.
#20 DanP ONLINE
DanP
  • 324 Thanks
  • 485 posts
Posted May 07, 2012 - 07:52 PM
Some more sandblasting tonight. I have gone through 150 lbs of blasting material. That is some tough paint.
#21 MH81 OFFLINE
Posted May 07, 2012 - 08:04 PM
Little parts are a pistol aren't they? Looking good so far, and :thumbs: to the progress.
As for the old, hard paint... A lot of guys will etank stuff for a while to loosen things a bit, make the blasting work a little easier.
#22 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted May 07, 2012 - 08:52 PM
Dan,
Try spraying all of the areas to be stripped, with Easy-Off oven cleaner, and let it sit for an hour. Then try blasting, and see if it makes a difference.
  • MH81 and DanP have said thanks
#23 DanP ONLINE
DanP
  • 324 Thanks
  • 485 posts
Posted May 09, 2012 - 08:59 PM
More sandblasting and priming tonight. I did spray some of the metal with oven cleaner and I think it helped a little but boy does it stink! I hope to get it all sandblasted and primed by the weekend.
#24 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted May 09, 2012 - 09:05 PM
Yeah, sorry Dan, I guess I should have mentioned the stinky part. After you use it a couple of times, you don't mind it as much.
#25 DanP ONLINE
DanP
  • 324 Thanks
  • 485 posts
Posted May 10, 2012 - 08:27 PM
Another night of sandblasting and priming. I worked on the Massey electric 3 point lift while the air compressor was building up.
#26 DanP ONLINE
DanP
  • 324 Thanks
  • 485 posts
Posted May 13, 2012 - 05:58 PM
I spent the best part of the day sandblasting and priming. I got it all done except the hood and hitch. I ran out of sand. I did discover one thing, I had been using the black blasting material I got from Menards it did not cut the paint very well so I tried some silica sand and it made a big difference. I wish I had done that 4 bags ago. The only problem is you are not suppose to breath in silica dust so you have to wear a mast under the hood. It is already hot enough. Now it is time for some sanding and painting. I sure hope I can figure out where all those parts go, there are a lot of pieces to that tractor.
#27 DanP ONLINE
DanP
  • 324 Thanks
  • 485 posts
Posted May 28, 2012 - 07:00 PM
Well I got back to work on the B10 today. Finished sandblasting the hood and hitch then primed them. I got all the cream stuff painted and in a few days I will clear coat them. Then I can paint the yellow, still waiting on some parts so I can paint them but they should be here in the next couple days. Boy I hope I can get this thing back together there are a lot of parts to this thing.
#28 KennyP ONLINE
  • 38,377 Thanks
  • 45,933 posts
Posted May 29, 2012 - 05:30 AM
Looking good, Dan! Best of luck putting it back together. I still have 2 pieces I need to put back on the GTV!
#29 DanP ONLINE
DanP
  • 324 Thanks
  • 485 posts
Posted May 29, 2012 - 07:48 PM
I got a box full of parts today, now I can finish the project. I still have tires to buy and decals to buy and a few other parts that I am sure I don't know about yet. But it is coming along fine, I should show some progress in a few days.
#30 MH81 OFFLINE
Posted May 29, 2012 - 11:25 PM
Dan, glad to hear you have some more puzzle pieces.
Thanks for the update.
