Speedex Hydraulics Part Question
1 reply to this topic
#1 glgrumpy OFFLINE
  • 8,816 Thanks
  • 8,014 posts
Posted April 25, 2012 - 11:59 PM
Have a late 2031 and is more like a STrongland tractor, than a speedex. It has full hydraulic power steering. There is a box mounted on frame that a lot of hoses in system go to, but has no mechanical moving parts. Is this because of the steering? or some other reason. I have 3pt and deck lift, each with it's own cylinder, two valves in control. There is no mechanical hook-up to steering, if the tractor isn't running, you barely get any movement to steer and push around.
#2 TUDOR OFFLINE
TUDOR
  • 565 Thanks
  • 507 posts
Posted April 26, 2012 - 01:10 PM
The box is the power steering control valve. There's only a fluid link between the steering wheel a the cylinder.
See pages 4 & 6 for the explanation and schematic.
http://www.vickershy.../pdf/11-872.pdf
I guess I forgot to push the POST button when I originally answered last night.
Edited by TUDOR, April 26, 2012 - 01:13 PM.
