Jd400 Died While Mowing, Now Wont Start
24 replies to this topic
#16 nathanatfork OFFLINE
nathanatfork
  • 5 Thanks
  • 51 posts
Posted April 25, 2012 - 06:30 PM
There is a 25 amp inline circuit breaker on the red wire between the battery and the key switch. Checked it and it is good.
There is a seat saftey switch in the wiring diagram but either mine doesnt have one or it was removed in the past.
There is only one wire going into the antidieseling solenoid and it comes from the coil. Dont have any juice going into it since no juice to the coil, but it does show and lose continuit when pushing in and pulling out the button it it, so we are taking that as a sign that its good.
#17 olcowhand OFFLINE
  • 38,813 Thanks
  • 30,704 posts
Posted April 25, 2012 - 06:33 PM
I was going to look at the service manual to try and help more. but I am maxed out on downloads for the day. :( I'll see if I can find another copy to look at. Good luck in the mean time.
Chris, you shouldn't have a max on downloading. I'll have George check that out when he gets time, which may take some time as he's very busy with server issues.
  • chris m said thank you
#18 chris m OFFLINE
chris m
  • 3,318 Thanks
  • 4,048 posts
Posted April 25, 2012 - 06:46 PM
No problem. I just went crazy looking at the MF stuff lastnight LOL.
#19 JDBrian OFFLINE
  • 9,599 Thanks
Posted April 25, 2012 - 06:56 PM
Take a good look at the 2 diagrams posted earlier in this topic. If you know what your ser. no. is you can tell which diagram applies. You should be able to trace the +12v from the ignition switch to the coil and determine where you are loosing it. Sometimes there are bad connections in the wiring just from age, dirt and corrosion of contacts.
#20 chris m OFFLINE
chris m
  • 3,318 Thanks
  • 4,048 posts
Posted April 25, 2012 - 07:09 PM
I was hoping a JD Pro would come on. :smilewink:
#21 nathanatfork OFFLINE
nathanatfork
  • 5 Thanks
  • 51 posts
Posted April 25, 2012 - 07:48 PM
Ok guys. THANK YOU all. Got it fixed. I did like yall said and double checked the wire from the ignition to the coil. turns out after removing the battery tray, it split off to go to safety switched for the belly pto and the seat safety switch. Apparently whoever removed the seat safety switch rigged it loosely and the two wires that were supposed to go to the seat switch had come disconnected. Stuck them back together and it start right up now. Now Ive got to put my whole mower back together though.
Thanks again for everyones help and for pointing me in the right direction. Yall are the BEST!
#22 chris m OFFLINE
chris m
  • 3,318 Thanks
  • 4,048 posts
Posted April 25, 2012 - 07:53 PM
That's great news!!!!! I just felt bad not being able to help you in person. Electrical troubles are bad enough when you can physically work on it. But even tougher to try and figure with out seeing things first hand. Good Job!!!
#23 olcowhand OFFLINE
  • 38,813 Thanks
  • 30,704 posts
Posted April 25, 2012 - 08:31 PM
Glad you got her going. I didn't add anything as Chris & Brian had you covered pretty well.
#24 Trav1s OFFLINE
Trav1s
    Got points?
  • 2,988 Thanks
  • 4,156 posts
Posted April 25, 2012 - 08:49 PM
Great news! Glad the gang here got you going.
#25 JDBrian OFFLINE
  • 9,599 Thanks
Posted April 26, 2012 - 04:15 AM
When you are troubleshooting these older tractors you can't take anything for granted. It's often the thing that you can't see or don't know about that gives you grief. That's why access to wiring diagrams are such a great help. Too bad JD is anal about manuals!! Access to service info for these tractors is a chronic issue that is bad for the brand IMO!!
