I Need A Complete Rebuild Kit For A Kohler K160
2 replies to this topic
#1 antiquetractors OFFLINE
antiquetractors
  • 280 Thanks
  • 506 posts
Posted April 23, 2012 - 12:27 PM
I have found myself in need of a complete rebuild kit since my motor decided to throw a rod. Will a k161 kit work? the gasket kits will work for either motor but I don't know about the internals. Does anyone have a favorite supplier that has a kit?
Thanks
#2 josh deaven OFFLINE
josh deaven
  • 479 Thanks
  • 574 posts
Posted April 23, 2012 - 07:49 PM
You should be able to bore the engine out and use 7hp rebuild parts.First ? are you going to use the tractor as a work tractor or a show tractor?If you are going to use it then I would buy all kohler parts.If it is a show tractor you can get rotary parts or stens.Let me know if you need any more help.Later Josh
#3 jweaver OFFLINE
jweaver
  • 5 Thanks
  • 22 posts
Posted April 24, 2012 - 08:10 AM
i would not use stens not very good quality specs are off go to your napa dealer they have realy good prices on the kohler kit and they have a realy good aftermarket kit that i have used alot and never had and problems
  • antiquetractors said thank you
