Wiring Question
8 replies to this topic
#1 Salatino OFFLINE
Salatino
  • 29 Thanks
  • 188 posts
Posted April 22, 2012 - 03:18 PM
I think this came up a few months back but what size wire do you guys usually run when you rewire up your gts'. A while back I was having problems in the switch on the 104, Basically where the wires & plug went together were rotted out and crackin, got that fixed, redone the voltage reg, - star/gen done. Since I'm waiting on the head to get back from the machine shop and got a lil time I took the old harness out, it was in bad shape , oh yeah the po had done a few things to it that I had to fix, I was wondering what size ahould run the batt. wires in, I'm usin the gas % oil resistant 10 awg, maybe a lil much but uts what I had. I WOULD LIKE TO USE SOMTHING A LIL BIGGER ON THE BATT. CABLES. sorry bout the caps
#2 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted April 22, 2012 - 03:26 PM
For battery cables bigger is better. anything form 6 gauge to 4/0, I think I usually use something like 6 or 8 gauge myself.
#3 Salatino OFFLINE
Salatino
  • 29 Thanks
  • 188 posts
Posted April 22, 2012 - 03:33 PM
eah thats what I was thinkin , when I said bigger I meant somthing bigger then what came from the factory. I did pick up a few of them copper lug trminals for them.
#4 TUDOR OFFLINE
TUDOR
  • 566 Thanks
  • 507 posts
Posted April 22, 2012 - 04:13 PM
I use battery cables out of old cars. If it's good enough to turn over a 350 Chevy at -30* F, it should be good enough for a GT engine at -30* F.
#5 JDBrian OFFLINE
  • 9,655 Thanks
  • 14,162 posts
Posted April 22, 2012 - 05:20 PM
I recently replaced the cables on my 314. I went to the auto parts store and bought the smallest cables they had which are still way bigger than what was on it. I think they are 4 gauge but I'm not sure. They were cheap. Less than 10$ for 15" length I needed with nice terminals on the ends.
#6 caseguy OFFLINE
  • 1,629 Thanks
Posted April 22, 2012 - 05:52 PM
Most auto parts stores carry them in 4 AWG. I usually make my own. I have a lot of old 6 AWG, THHN wire in red and black. That should be fine for any GT application, but like Chris said, bigger is always better when it comes to battery cables. use the 6 AWG because it's what I have at hand. It's good for up to 60 amps in conduit, 100 amps in free air. I figure that under a hood is somewhere in between those LOL. That's a continuous rating BTW. You should never see more than a surge when starting that even approaches that.
#7 drbish ONLINE
drbish
    Collecter
  • 1,576 Thanks
  • 1,374 posts
Posted April 22, 2012 - 06:31 PM
There is a diagram of starter generator trouble shooting in an earlier posthttp://gardentractor...__fromsearch__1t.The second download has the size of wiring b/s recommends
#8 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted April 22, 2012 - 06:53 PM
I rewired the Caterpillar with 12 gauge on all circuits and 10 gauge on the car alternator circuit. Then for the starter and battery cables I used 4 gauge battery cable. The standard size was 6 gauge. Now when I turn the key it cranks like crazy!! Good luck, don't fry any magnetos!!
#9 Salatino OFFLINE
Salatino
  • 29 Thanks
  • 188 posts
Posted April 22, 2012 - 07:31 PM
I've got a couple old ground wires from old trucks I've had I thought about using , I noticed both the ground and neg batt. wires had several bare spots in them, I've been telling myself I was gonna go ahead and finish rewiring it but kept puttin it off. lol I have no excuse now but to do it. the main reason was I wanted to get the old harnesss out b4 I finished it up. Hopefully it'll turn over a lil faster now, it was kinda sluggish / slow turnin. lol we'll see. thanks everyone
