Mf 85
4 replies to this topic
#1 earthworm OFFLINE
earthworm
  • 3 Thanks
  • 19 posts
Posted April 21, 2012 - 06:08 PM
This MF 85, from the 80s or 90s (a guess) is just a lawn tractor, but it works, up to several days ago.
Now, I think the problem is the deck drive pulley tension idler. The replacement is several mm less high, and I think this causes belts to be thrown...The ACE hardware store pulley selection is limited, but they are far nicer to work with than Lowes or HD..
Please advise, TIA
  • pmichel777 said thank you
#2 HowardsMF155 OFFLINE
  • 3107 Thanks
  • 3091 posts
Posted April 21, 2012 - 07:18 PM
If you want to deal locally, look for a Tractor Supply, perhaps a Northern Tool, or Agrisupply.
On the mail-order side, try one of our sponsers, they are listed in the "Forum" category. They can probably find you a decent used replacement.
#3 olcowhand OFFLINE
  • 44107 Thanks
  • 32302 posts
Posted April 21, 2012 - 07:32 PM
If the belt fits within the pulley fine, and the problem is the pulley isn't aligning with the driven & drive pulleys, then you can use washers under the pulley hub to raise it.
#4 earthworm OFFLINE
earthworm
  • 3 Thanks
  • 19 posts
Posted April 22, 2012 - 05:51 AM
Thanks for the replies.
So, its another session of down and dirty,
A bit of a red face, I had forgotten all about TractorSupply.
#5 KennyP ONLINE
  • 53218 Thanks
  • 53323 posts
Posted April 22, 2012 - 08:32 AM
I'm with Daniel! If you have room on the spindle for the offending pulley, raise it up to align better!
