Ford Lgt 165 Voltage Regulator
4 replies to this topic
#1 nycub122 OFFLINE
nycub122
  • 25 Thanks
  • 74 posts
Posted April 21, 2012 - 02:14 PM
Are there any sustitutes for the Ford voltage regulator used on a 1976 LGT 165?
I know that a replacement from New Holland is about $110 and was wondering if a
regulator from some other tractor using a Kohler K341 could be substituted?
Is the regulator a Ford exclusive or is it a Kohler part?
Any thoughts would be ppreciated.
Thanks
GEL
#2 KennyP OFFLINE
  • 40,240 Thanks
  • 46,811 posts
Posted April 21, 2012 - 05:34 PM
I looked up the numbers for this regulator and found this:
It's at this web site:
http://www.rcpw.com/...=23&search.y=12
#3 poncho62 OFFLINE
poncho62
  • 1,996 Thanks
  • 1,744 posts
I would think that just about any regulater from a Kohler "K" engineed tractor would work........Just a thought, but more times than not, when I was having trouble with one of those, it was just a loose coonection, mostly at that 3 pronged plug. that plugs into it.
Edited by poncho62, April 21, 2012 - 05:34 PM.
#4 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted April 21, 2012 - 06:49 PM
Good point Poncho. You can usually remove the connections from the plug and clean them if you need to. Dirt and corrosion can easily interfere with a good connection. Even a small amount of resistance will stop the regulator from working properly. The regulator also needs a good connection from it's case back to the battery negative terminal so check that as well.
#5 olcowhand ONLINE
  • 42,520 Thanks
  • 31,838 posts
One off an Onan will work also. I swap them around all the time. These regulators MUST have a good ground to function!
