Who Can Make A Coulter Wheel?
31 replies to this topic
#1 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted April 19, 2012 - 09:33 PM
Ok, my Springfield plow's coulter wheel is an odd size (8.75" OD) and is worn out and bent, same with its hub. The hub rides on a 3/8" bolt (can't recall the width). Thought about using a saw blade as a coulter wheel but doubt it would hold up long. I know some of you guys are fabricators... and machinists, with skills and equipment I am not qualified to use lol. So, my question is, can anyone make a coulter wheel that would work for me? It can be one piece, two piece, or even three depending on your method of going about the hub. Heck, even 4 pieces, as long as it works, bushings or not lol. Any takers on this one?
Thanks in advance, Casey
Edited by wvbuzzmaster, April 19, 2012 - 09:37 PM.
#2 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted April 19, 2012 - 09:35 PM
by the way, don't need to win a beauty contest with it, and its a proprietary coulter design from the factory, so no one will know what it should look like, so open design on this one guys.
Edited by wvbuzzmaster, April 19, 2012 - 09:36 PM.
#3 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted April 19, 2012 - 10:08 PM
That's funny I have a paper plate with my food on it right now that has the same OD! Will that work? :laughingteeth: JK LOL!!! I'll look around and see if I have anything to make one out of.
  • wvbuzzmaster said thank you
#4 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted April 19, 2012 - 10:13 PM
Paper plate probably wont work, but if you have anything that does, that would be great. I am open to any OD from 8"-8.75". Not sure if 9" would work, but it might. I have to doublecheck the through bore of the hub tomorrow, but its probably going to need to be around 1-1.5". Don't quote me on that, I will get a true dimension tomorrow morning before I head to work.
Edited by wvbuzzmaster, April 19, 2012 - 10:14 PM.
  • chris m said thank you
#5 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted April 19, 2012 - 10:23 PM
Ok Casey, I went right out to the shop and fabed this up. I even had to drill a 3/8 hole in the bracket LOL. :laughingteeth:PICT1177.JPG PICT1178.JPG
  • MH81, Texas Deere and Horse and wvbuzzmaster have said thanks
#6 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted April 19, 2012 - 10:37 PM
Chris,
I have a bracket, just need a coulter wheel. The plate is funny, but it probably won't hold up. Any other items in there?
#7 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted April 20, 2012 - 12:01 AM
Might be best to keep it closer to 8" diameter for clearance.
#8 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted April 20, 2012 - 12:07 AM
I lost the internet at midnight, so I went out looking around the shop. Nothing yet, but I'll look around in the morning to see if I have anything to make the hub and the coulter. Who knows maybe another member already has one laying around that they would part with? I'll let you know tomorrow how I make out though.
#9 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted April 20, 2012 - 12:31 AM
how about a picture of the one you have and some detail measurements. Might have one just lying under the bench or a least something closer than that fine looking paper plate. By the way the best plate to use is Chinet brand, you know the ones with the 3 compartments to keep your veggies out of your pudding.
#10 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted April 20, 2012 - 12:54 AM
I just had to do it! When I measured my plate and it was the same size I went right out to the shop with it LOL.It was good too cause I needed a good laugh today.
#11 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted April 20, 2012 - 07:01 AM
Well, I would but don't care for the design as much. The thru bore needs to be about 1 inch. Let's try to keep diameter around 8 inches. Immigration be nice to have bushing in the hub though. If anyone wants to try making a one piece coulter wheel/hub setup with bushings in its hub that would be impressive. :)
#12 MH81 OFFLINE
  • 29,979 Thanks
Posted April 20, 2012 - 07:14 AM
Auto correct bit you again... :laughingteeth:
#13 MH81 OFFLINE
  • 29,979 Thanks
Posted April 20, 2012 - 07:17 AM
I bet the OEM didn't have that floral pattern.
#14 KennyP ONLINE
  • 40,978 Thanks
  • 47,148 posts
Posted April 20, 2012 - 07:22 AM
I kinda like the floral pattern my self! Goes with the weeds/grass it would fall apart into!
#15 Alc ONLINE
  • 7,255 Thanks
  • 7,595 posts
Posted April 20, 2012 - 07:50 AM
Casey , have an old concrete saw blade here at work , give me the size you want the OD , I'll cut it with the plasma cutter , then we'll work on what bearing or bushing you'll need , Al
