Plastic Tank Petcocks?
4 replies to this topic
#1 glgrumpy OFFLINE
  • 8,746 Thanks
  • 7,983 posts
Posted April 19, 2012 - 06:07 PM
Have a newer Power King and think I saw same on an IH one time. Have plastic gas tanks in later models. The shut-off petcocks are usually a push-in item, fitting into a rubber grommet like part. The grommets get hard and dry out, break. Those valves have a small screen on them sometimes. Wondering if those are a common item I can buy? Suggestions on what brand or where? Would like the new grommet and valve with screen. I hate plastic tanks!
#2 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,163 Thanks
  • 1,331 posts
Posted April 19, 2012 - 06:17 PM
I believe the grommet you are looking for is NAPA and Prime Line part number 7-07461. Around $2.50.
Bill
  • caseguy said thank you
#3 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted April 19, 2012 - 06:43 PM
I know what you mean. The petcock is stuck in the on position on my 314. I could not budge it. I didn't want to risk busting the plastic tank by trying to remove the valve so I installed an inline shutoff valve and just left it alone.
#4 caseguy OFFLINE
  • 1,629 Thanks
Posted April 19, 2012 - 07:25 PM
That's a regular maintenance item on the newer Wheel Horse models (~ 1978 and newer) I have always thought they were a Wheel Horse only part and they get like $7-$8 for them (I have 3 or 4 in a box up in the garage...like I said, a COMMON problem!). I'm certainly gonna check out the NAPA part and see if it will work for me too!
#5 massey driver ONLINE
massey driver
  • 1,483 Thanks
  • 1,592 posts
Posted April 19, 2012 - 08:22 PM
Another source is on a snowmobile tank,They use the same rubber groumet that the steel fuel line elbows go into.The plastic/rubber lines hook up to the elbow on the inside and out side of the tanks. At least this is were I've been getting mine from. Larry
